Simplified Chinese Solaris User's Guide
Chapter 10 Simplified Chinese Printing Facilities
This chapter describes how to print Simplified Chinese text to a line printer. The chapter also provides information on how to use the mp utilities to print to a PostScript printer or to a line printer.
Printing Chinese Output From a Command Line
This section provides information that you can use to print from a command line with the lp command and the mp program.
Printing With a Line Printer
You can use the commands in this section to print files of different formats to a line printer.
    Use this command to print an EUC file.
system% lp EUC_filename
    Use this command to print a GB format file to a printer that supports GB format.
    system% lp -T GB GB_filename
Printing With the mp Utility
The enhanced mp print utility is available in the current Simplified Chinese Solaris release. You can use mp to print zh files in zh locale or UTF-8 files in zh.UTF-8 locales.
The output from the utility is standard PostScript that you can send to any PostScript printer.
Use the following command to print a file with the mp utility.
system% mp filename | lp
You can also use the utility as a filter because mp accepts stdin stream.
system% cat filename | mp | lp
You can set the utility as a print filter for a line printer. For example, the following command sequence signals the print service that the printer lp1 accepts only mp format files. The command also installs the printer lp1 on port /dev/ttya. See the lpadmin(1M) man page for more details.
system% lpadmin -p lp1 -v /dev/ttya -I MP
system% accept lp1
system% enable lp1
You can use the following command to add a filter for an LP print service.
system% lpfilter -f filtername \
-F pathname
The filter converts the default input type to PostScript output with the /usr/bin/mp command.
To print a UTF-8 text file, use a command line such as the following.
system% lp -T MP UTF-8-file
For more details on the mp(1), see the man page.
Using mp as an Xprt (X Print Server) Client
Using mp as an Xprt client enables mp to print the output of any printer connected to a network supported by an Xprt print service. As an Xprt client, mp supports PostScript and many versions of PCL.
The Xprt client attempts a connection to an Xprt server based on the following rules:
