Using the New ChuYin input method, press the Shift key with the A, B, C, D, E, F, or G key to select the preedit string.
Press an edit key.
The following table shows the definitions of the edit keys.
ChuYin keystroke
Moves to the start of the preedit line
Moves to the end of the preedit line
Moves the caret in the preedit line to the right.
Deletes the PinYin character following the caret on the preedit line.
Deletes the PinYin character preceding the caret on the preedit line.
