As a print filter, mp generates a properly formatted version of contents in PostScript format. The PostScript output file contains glyph images from Solaris-resident scalable or bitmap fonts, depending on each locale's system font configuration for mp. The mp filter is enhanced in the current Solaris release to print files with different encoding text in the corresponding Asian locales.
The following command line will print a file containing Traditional Chinese characters, with or without ASCII/English characters:
system% mp -L $LANG filename | lp -d printer |
The file may contain ASCII/English characters as well as Traditional Chinese. Refer to the mp(1) man page for more detailed information.
You can use the mp utility as a filter because mp accepts the stdin stream.
system% cat filename | mp | lp |
You can set the utility as a printing filter for a line printer. For example, the following command sequence tells the printer service LP that the printer lp1 accepts only mp format files. This command also installs the printer lp1 on port /dev/ttya. See the lpadmin(1M) man page for more details.
system% lpadmin -p lp1 -v /dev/ttya -I MP system% accept lp1 system% enable lp1 |
You can add the lpfilter utility for a filter by using the lpfilter(1M) command as follows:
system% lpfilter -f filtername -F pathname |
The lpfilter command tells lp that a converter (in this case, xutops) is available through the filter description file named path name. The pathname can be determined as follows:
Input types: simple Output types: MP Command: /usr/bin/mp |
The filter converts the default type file input to PostScript output using/usr/bin/mp.
To print a UTF-8 text file, use the following command:
system% lp -T MP UTF-8-file |
For more details on the mp command, refer to the mp(1) man page.
