The System Management Agent supports the following MIBs
Defined in RFC 2576. See http://www.ietf.org/rfc/rfc2576.txt
Defined in RFC 3417. See http://www.ietf.org/rfc/rfc3417.txt
Defined in RFC 3412. See http://www.ietf.org/rfc/rfc3412.txt
Defined in RFC 3413. See http://www.ietf.org/rfc/rfc3413.txt
Defined in RFC 3414. See http://www.ietf.org/rfc/rfc3414.txt
Defined in RFC 3415. See http://www.ietf.org/rfc/rfc3415.txt
Defined in RFC 3418. See http://www.ietf.org/rfc/rfc3418.txt
Defined in RFC 1213. See http://www.ietf.org/rfc/rfc1213.txt
Defined in RFC 2790. See http://www.ietf.org/rfc/rfc2790.txt
Related to migration from the Solstice Enterprise Agents software. For further information, see Migration From Solstice Enterprise Agents Software. For information about the migration of applications from the Solstice Enterprise Agents software, see Chapter 10, Migration of Solstice Enterprise Agents to the System Management Agent, in Solaris System Management Agent Developer’s Guide.
You can see a list of those MIBs that are initialized after starting the System Management Agent by following the procedure described in To See Which MIBs Are Initialized.
You can see the text files of MIB definitions at /etc/sma/snmp/mibs/.
