Solaris System Management Agent Developer's Guide
Entity MIB API
This section lists and describes the API functions that are provided in the libentity.so module. Use these functions in your module when you want to use the Entity MIB.
Table 9–1 Entity MIB Functions Listed by Category
Function Category
Functions
Physical Table Functions
allocPhysicalEntry()
getPhysicalEntry()
deletePhysicalTableEntry()
makePhysicalTableEntryStale()
makePhysicalTableEntryLive()
getPhysicalStaleEntry()
getAllChildrenFromPhysicalContainedIn()
Physical Contains Table Functions
addPhysicalContainsTableEntry()
deletePhysicalContainsTableEntry()
deletePhysicalContainsParentIndex()
deletePhysicalContainsChildIndex()
getPhysicalContainsChildren()
Logical Table Functions
allocLogicalEntry()
getLogicalTableEntry()
deleteLogicalTableEntry()
makeLogicalTableEntryStale()
makeLogicalTableEntryLive()
getLogicalStaleEntry()
LP Mapping Table Functions
addLPMappingTableEntry()
deleteLPMappingTableEntry()
deleteLPMappingLogicalIndex()
deleteLPMappingPhysicalIndex()
Alias Mapping Table Functions
addAliasMappingTableEntry()
deleteAliasMappingTableEntry()
deleteAliasMappingLogicalIndex()
deleteAliasMappingPhysicalIndex()
The entPhysicalTable contains one row for each physical entity. The table contains at least one row for an overall physical entity. Each table entry provides objects to help an NMS to identify and characterize the entry. Other objects in the table entry help an NMS to relate the particular entry to other entries in the table.
The following functions are for use with the entPhysicalTable in the Entity MIB.
Synopsis
extern int allocPhysicalEntry(int physidx, entPhysicalEntry_t *newPhysEntry);
Description
Allocates an entry in the entPhysicalTable. The physidx parameter is the requested physical index. If physidx= 0, the function tries to use the first available index in the table. If physidx= 1 or greater, the function tries to use the specified index. If the specified index is in use, the function returns the first available index in the table. As a result, the returned index might not be the same as the requested physical index.
The memory that is associated with newPhysEntry can be freed. The function creates an internal copy of the data.
The entPhysicalEntry_t structure definition is shown in entPhysicalEntry_t Structure. Special cases for newPhysEntry values are handled as shown in the following table.
Object
Value of newPhysEntry
Entity MIB module handling
entPhysicalDescr
NULL
reject
entPhysicalVendorType
NULL
{ 0, 0 }
entPhysicalName
NULL
entPhysicalHardwareRev
NULL
entPhysicalFirmwareRev
NULL
entPhysicalSoftwareRev
NULL
entPhysicalSerialNum
NULL
entPhysicalMfgName
NULL
entPhysicalModelName
NULL
entPhysicalAlias
NULL
entPhysicalAssetID
NULL
Returns
index
allocated to the physical entry.
-1
if an error occurs when adding the entry. Check the log for more details.
getPhysicalEntry()
Synopsis
entPhysicalEntry_t *getPhysicalEntry(int index);
Description
Gets the actual physical table entry for the specified index. The caller must not change the values or release the memory of the entry that is returned. The entPhysicalEntry_t structure definition is shown in entPhysicalEntry_t Structure.
Returns
getPhysicalEntry() returns the entry for the specified index.
Returns NULL if an error occurs while finding the entry, or if a stale entry exists. In this context, stale means that the entry details are present in the agent memory but should not be displayed during any SNMP operation.
Synopsis
extern int deletePhysicalTableEntry(int xPhysicalIndex);
Description
Deletes the physical table entry that is associated with the specified xPhysicalIndex. The instances of xPhysicalIndex in the entAliasMappingTable, entLPMappingTable and the entPhysicalContainsTable are also deleted to maintain integrity among the various Entity MIB tables.
Returns
0
for success.
-1
if the xPhysicalIndex is not found.
-2
if a stale entry was found for the xPhysicalIndex. In this context, “stale” means that the entry details are present in the agent memory but are not displayed during any SNMP operation.
Synopsis
extern int makePhysicalTableEntryStale(int xPhysicalIndex);
Description
Makes the physical table entry that is associated with the xPhysicalIndex become stale. In this context, “stale” means that the entry details are present in the agent memory but are not displayed during any SNMP operation. The index that was allocated to a stale entry is not allocated to another entry.
When you make an entry become stale, the instances of xPhysicalIndex in the entAliasMappingTable, entLPMappingTable and entPhysicalContainsTable are also deleted. The deletion maintains integrity among the various Entity MIB tables. Before you make an entry stale, you might want to store the entries that are to be deleted from the tables.
The physical table entry can be made available or “live” again by calling the makePhysicalTableEntryLive() functions, which is described in makePhysicalTableEntryLive().
Returns
0
for success.
-1
-2
if a stale entry already exists for xPhysicalIndex.
Synopsis
extern int makePhysicalTableEntryLive(int xPhysicalIndex);
Description
Makes the stale physical table entry associated with the xPhysicalIndex live. In this context, “live” means that the entry details that are present in the agent memory are displayed during SNMP operations. The entry can be made stale by calling the makePhysicalTableEntryStale() function. In this context, “stale” means that the entry details are present in the agent memory but are not displayed during any SNMP operation.
If a stale entry is made live again, you must recreate the corresponding entries that were deleted in the entPhysicalContainsTable, the entLPMappingTable, and the entAliasMappingTable. Use the appropriate functions for adding an entry to each table: addPhysicalContainsTableEntry(), addLPMappingTableEntry(), and addAliasMappingTableEntry().
Returns
0
for success.
-1
-2
if a live entry already exists for xPhysicalIndex.
Synopsis
entPhysicalEntry_t *getPhysicalStaleEntry(int index);
Description
Gets the stale physical table index structure for the specified index. In this context, stale means that the entry details are present in the agent memory but are not displayed during any SNMP operation. The entPhysicalEntry_t structure definition is shown in entPhysicalEntry_t Structure.
Returns
Returns the index structure for the specified index.
Returns NULL if an error occurs while finding the entry, or if a live entry exists.
Synopsis
int getAllChildrenFromPhysicalContainedIn(int parentIndex);
Description
Gets the indexes for all children in the entPhysicalTable that have parentIndex as their parent in the entPhysicalContainedIn field.
Returns
Returns an array of integer indexes with null termination.
Returns NULL if no children, or invalid index, or not enough memory when allocating the array.
The entPhysicalContainsTable exposes the container relationships between physical entities. This table provides the same information that can be found by constructing the virtual containment tree for a given entPhysicalTable, but in a more direct format.
The following functions are for use with the entPhysicalContainsTable in the Entity MIB:
Synopsis
extern int addPhysicalContainsTableEntry(int entPhysicalIndex, int childIndex);
Description
Adds an entry to the entPhysicalContainsTable table for the specified entPhysicalIndex and childIndex. The entPhysicalContainedIn OID that is present in the entPhysicalTable for the childIndex might be replaced by the OID for entPhysicalIndex. The OID is replaced if the entPhysicalIndex has a lower index than the original index.
Returns
0
for successful addition.
-1
for failure to add.
-2
for stale index.
1
if the entry already exists for the specified entPhysicalIndex and childIndex.
Synopsis
extern int deletePhysicalContainsTableEntry(int parentIndex, int childIndex);
Description
Deletes the parentIndex or childIndex entry that is present in the entPhysicalContainsTable.
Returns
0
for success.
-1
for failure.
-2
for stale entry, either parent or child, or both.
Synopsis
extern int deletePhysicalContainsParentIndex(int parentIndex);
Description
Deletes all entries in the entPhysicalContainsTable where the parent index is equal to the specified parentIndex.
Returns
number
of children successfully deleted for the specified parent.
-1
for failure.
-2
for stale parent entry.
Synopsis
extern int deletePhysicalContainsChildIndex(int childIndex);
Description
Deletes all entries in the entPhysicalContains table where the child index is equal to the specified childIndex.
Returns
number
of parents successfully deleted for the specified child.
-1
for failure.
-2
for stale child entry.
Synopsis
extern int getPhysicalContainsChildren(int parentIndex);
Description
Get the indexes for all the children of the specified parent in the entPhysicalContainsTable.
Returns
Returns an array of integer indexes, with null termination.
Returns NULL if children exist, or if not enough memory exists when allocating the array. The array is a copy that should be freed when done.
The entLogicalTable table contains one row per logical entity. For agents that implement more than one naming scope, at least one entry must exist. Agents that instantiate all MIB objects within a single naming scope are not required to implement this table.
The following functions are for use with the entLogicalTable in the Entity MIB:
allocLogicalEntry()
Synopsis
extern int allocLogicalEntry(int logidx, entLogicalEntry_t *xnewLogicalEntry);
Description
Allocates an entry in the Logical Table. The logidx parameter is the requested logical index. If logidx= 0, the function tries to use the first available index in the table. If logidx= 1 or greater, the function tries to use the specified index. If the specified index is in use, the function returns the first available index in the table. As a result, the returned index might not be the same as the requested logical index.
The allocLogicalEntry() function returns the logical index that is allocated to the entry. The memory that is associated with xnewLogicalEntry can be freed. The function creates a internal copy of the data.
The entLogicalEntry_t structure definition is shown in entLogicalEntry_t Structure. Special cases for xnewLogicalEntry values are handled as shown in the following table.
Object
Value of xnewLogicalEntry
entLogicalDescr
NULL
reject
entLogicalType
NULL
{ 1,3,6,1,2,1 }
entLogicalCommunity
NULL
entLogicalTAddress
NULL or ""
reject
entLogicalTDomain
NULL
reject
entLogicalContextEngineId
NULL
entLogicalContextName
NULL
Returns
Returns the index allocated to the logical entry.
Returns -1 for error in adding the entry. Check the log for more details.
Synopsis
entLogicalEntry_t *getLogicalTableEntry(int xLogicalIndex);
Description
This function gets the logical table index structure for a particular index. The caller must not change the value or release the memory of the entry that is returned. The entLogicalEntry_t structure definition is shown in entLogicalEntry_t Structure.
Returns
Returns the entry that is associated with xLogicalIndex.
Returns NULL on error in finding the entry, or if a stale entry exists.
Synopsis
extern int deleteLogicalTableEntry(int xLogicalIndex);
Description
Deletes the logical table entry that is associated with the xLogicalIndex. The instances of xLogicalIndex in the entAliasMappingTable and the entLPMappingTable are also deleted to maintain integrity among the various Entity MIB tables.
Returns
0
for success.
-1
if the xLogicalIndex is not found.
-2
if a stale entry was found for xLogicalIndex.
Synopsis
extern int makeLogicalTableEntryStale(int xLogicalIndex);
Description
Makes the logical table entry associated with the xLogicalIndex become stale. In this context, “stale” means that the entry details are present in the agent memory but are not displayed during any SNMP operation. The index that was allocated to a stale entry is not allocated to another entry.
When you make an entry become stale, the instances of xLogicalIndex in the entAliasMappingTable, entLPMappingTable and entPhysicalContainsTable are also deleted. The deletion maintains integrity among the various Entity MIB tables. Before you make an entry stale, you might want to store the entries that are to be deleted from the other tables.
The stale logical table entry can be made available again by calling the makeLogicalTableEntryLive() function, which is described in makeLogicalTableEntryLive().
Returns
0
for success.
-1
–2
Synopsis
extern int makeLogicalTableEntryLive(int xLogicalIndex);
Description
Makes the stale logical table entry associated with the xLogicalIndex become live. In this context, “live” means that the entry details that are present in the agent memory are displayed during any SNMP operations. The entry can be made stale by calling the makeLogicalTableEntryStale() function.
If an entry is made live again, you must recreate the corresponding entries that were deleted in the entPhysicalContainsTable, the entLPMappingTable, and the entAliasMappingTable. Use the appropriate functions for adding an entry to each table: addPhysicalContainsTableEntry(), addLPMappingTableEntry(), and addAliasMappingTableEntry().
Returns
0
for success.
-1
–2
if a live entry already exists for xLogicalIndex.
Synopsis
entLogicalEntry_t *getLogicalStaleEntry(int index );
Description
Gets the stale logical table index structure for the specified index. The caller must not change the values or release the memory of the entry that is returned. The entLogicalEntry_t structure definition is shown in entLogicalEntry_t Structure.
Returns
Returns the stale entry for the specified index.
Returns NULL if the entry is not found, or if a live entry exists.
The entLPMappingTable contains zero or more rows that associate logical entities to physical equipment. For each logical entity that is known by this agent, there are zero or more mappings to the physical resources that are used to realize that logical entity. An agent should limit the number and nature of entries in this table so that only meaningful and non-redundant information is returned. See the /etc/sma/snmp/mibs/ENTITY-MIB.txt file for more information about the entLPMappingTable.
The following functions are for use with the entLPMappingTable:
Synopsis
extern int addLPMappingTableEntry(int xentLogicalIndex, int xentPhysicalIndex );
Description
Adds an entry to the entLPMappingTable with the xentLogicalIndex as the primary index and xentPhysicalIndex as the secondary index.
Returns
0
1
if the entry already exists for the given xentPhysicalIndex and xentLogicalIndex.
-1
for failure to add.
-2
for stale index.
Synopsis
extern int deleteLPMappingTableEntry(int xentLogicalIndex, int xentPhysicalIndex );
Description
Deletes the entry of the LP Mapping table that uses the specified xentLogicalIndex as the primary index and xentPhysicalIndex as the secondary index.
Returns
0
for successful deletion.
-1
for failure to delete.
-2
for stale entry, either logical index or physical index, or both.
Synopsis
extern int deleteLPMappingLogicalIndex(int xentLogicalIndex);
Description
Deletes all the entries of the entLPMappingTable that have the xentLogicalIndex as the primary index.
Returns
number
of successfully deleted entries.
-1
for failure.
-2
for stale logical entry.
Synopsis
extern int deleteLPMappingPhysicalIndex(int xentPhysicalIndex);
Description
Deletes all the entries of the entLPMappingTable that have xentPhysicalIndex as the secondary index.
Returns
number
–1
if no entry was deleted.
-2
for stale physical entry.
The entAliasMappingTable contains zero or more rows that represent mappings of logical entity and physical entities for ports to external MIB identifiers. Each physical port in the system can be associated with a mapping to an external identifier. The external identifier is associated with a particular logical entity's naming scope. A wildcard mechanism is provided to indicate that an identifier is associated with more than one logical entity.
The following functions are for use with the entAliasMappingTable in the Entity MIB:
Synopsis
extern int addAliasMappingTableEntry(int xentPhysicalIndex, int xentLogicalIndex, oid* xAliasMapId, int xAliasMapIdSize);
Description
Adds an entry to the entAliasMappingTable with the xentPhysicalIndex as the primary index and xentLogicalIndex as the secondary index. xAliasMapId is the alias (OID) for the entry and xAliasMapIdSize is the size in bytes of xAliasMapId.
Note that if entAliasMapId = NULL, the request is rejected.
Returns
0
1
-1
for failure.
-2
for stale entry.
Synopsis
extern int deleteAliasMappingTableEntry(int xentPhysicalIndex, int xentLogicalIndex);
Description
Deletes the entry in the entAliasMappingTable that has xentPhysicalIndex as the primary index and xentLogicalIndex as the secondary index.
Returns
0
-1
for entry not found.
-2
for stale entry.
Synopsis
extern int deleteAliasMappingLogicalIndex(int xentLogicalIndex);
Description
Deletes all entries of the entAliasMappingTable that have xentLogicalIndex as the secondary index.
This function cannot be used to delete all indexes that have an xentLogicalIndex of zero. Use the deleteAliasMappingTableEntry() function to delete such entries one at a time, with the appropriate xentPhysicalIndex specified.
Returns
number
of entries successfully deleted.
-1
-2
Synopsis
extern int deleteAliasMappingPhysicalIndex(int xentPhysicalIndex);
Description
Deletes all entries in the entAliasMappingTable whose primary index matches the specified xentPhysicalIindex.
Returns
number
–1
–2
