The developer files are installed in the locations that are shown in the following table.
Table 1–1 File Locations for Developer Content|
Directory |
Developer Content |
/usr/demo/sma_snmp |
Sample modules for demonstration purposes. See Demonstration Modules for more information. |
/usr/sfw/bin |
Command line tools that are useful for developers. For more information on these tools, see SMA Tools. |
/usr/sfw/sbin |
Executable files for the snmpd agent daemon and snmptrapd trap daemon, which provide the SNMP services. |
/usr/sfw/lib |
The 32-bit shared libraries that contain the API functions from Net-SNMP, and the libentity.so library, which defines functions for using the Entity MIB. This directory is supplied on all Solaris platforms. See API Libraries for more information. |
/usr/sfw/lib/sparcv9 |
The 64-bit shared libraries that contain the API functions from Net-SNMP, and the libentity.so library, which defines functions for using the Entity MIB. This directory is supplied only on 64-bit Solaris on SPARC® platforms. See API Libraries for more information. |
/usr/sfw/include |
Header files needed by API libraries. |
/usr/sfw/doc/sma_snmp/html |
HTML documentation for Net-SNMP API functions. |
/etc/sma/snmp |
Configuration files that are used by the mib2c tool. |
/etc/sma/snmp/mibs |
The MIBs supported by the System Management Agent. |
/usr/perl5/vendor_perl/5.8.3/sun4-solaris-64int |
Perl modules needed by the mib2c tool. |
/usr/share/sma_snmp |
Source code for Net-SNMP. The code is provided in the SUNWsmaS package, which is not installed by default during Solaris installation. The package must be installed manually from the Solaris media. For instructions for installing the SUNWsmaS package, see the Solaris System Management Agent Administration Guide. |
