cpc_set_t *cpc_set_create(cpc_t *cpc);
int cpc_set_destroy(cpc_t *cpc, cpc_set_t *set);
int cpc_set_add_request(cpc_t *cpc, cpc_set_t *set, const char *event,
uint64_t preset, uint_t flags, uint_t nattrs,
const cpc_attr_t *attrs);
int cpc_set_request_preset(cpc_t *cpc, cpc_set_t *set, int index,
uint64_t preset);
The opaque data type cpc_set_t represents collections of requests. The collections are called sets. The cpc_set_create() function creates an empty set. The cpc_set_destroy() function destroys a set and frees all the memory used by the set. Destroying a set releases the hardware resources the set uses.
The cpc_set_add_request() function adds requests to a set. The following list describes the parameters of a request.
A string that specifies the name of the event to count.
A 64–bit unsigned integer that is used as the initial value of the counter.
The results of the logical OR operation applied to a group of request flags.
The number of attributes in the array that attrs points to.
A pointer to an array of cpc_attr_t structures.
The following list describes the valid request flags.
This flag enables counting of events that occur while the CPU is executing in user mode.
This flag enables counting of events that occur while the CPU is executing in privileged mode.
This flag requests notification of hardware counter overflow.
The CPC interfaces pass attributes as an array of cpc_attr_t structures.
When the cpc_set_add_request() function returns successfully, it returns an index. The index references the data generated by the request added by the call to the cpc_set_add_request() function.
The cpc_set_request_preset() function changes the preset value of a request. This enables the re-binding of an overflowed set with new presets.
The cpc_walk_requests() function calls a user-provided action() routine on each request in cpc_set_t. The value of the arg parameter is passed to the user routine without interpretation. The cpc_walk_requests() function allows applications to print the configuration of each request in a set. The syntax for the cpc_walk_requests() function is as follows:
void cpc_walk_requests(cpc_t *cpc, cpc_set_t *set, void *arg,
void (*action)(void *arg, int index, const char *event,
uint64_t preset, uint_t flags, int nattrs,
const cpc_attr_t *attrs));
