Programming Interfaces Guide
check -all [-frames n] [-match m]
Equivalent to check -access; check -memuse [-frames n] [-match m]. The value of rtc_biu_at_exit dbxenv variable is not changed with check -all. So, by default, no memory use report is generated at exit.
