Programming Interfaces Guide
Memory Segment Creation and Destruction
Establishing a new memory segment with rsm_memseg_export_create enables the association of physical memory with the segment at creation time. The operation returns an export-side memory segment handle to the new memory segment. The segment exists for the lifetime of the creating process or until destroyed with rsm_memseg_export_destroy.
Note –
If destroy operation is performed before an import side disconnect, the disconnect is forced.
Segment Creation
int rsm_memseg_export_create(rsmapi_controller_handle_t controller, rsm_memseg_export_handle_t *memseg, void *vaddr, size_t size, uint_t flags);
This function creates a segment handle. After the segment handle is created, the segment handle is bound to the specified virtual address range [vaddr..vaddr+size]. The range must be valid and aligned on the controller's alignment property. The flags argument is a bitmask, which enables:
Note –
The RSM_LOCK_OPS flag is not included in the initial release of RSMAPI.
Return Values: Returns 0 if successful. Returns an error value otherwise.
RSMERR_BAD_CTLR_HNDL
Invalid controller handle
RSMERR_CTLR_NOT_PRESENT
Controller not present
RSMERR_BAD_SEG_HNDL
Invalid segment handle
RSMERR_BAD_LENGTH
Length zero or length exceeds controller limits
RSMERR_BAD_ADDR
Invalid address
RSMERR_PERM_DENIED
Permission denied
RSMERR_INSUFFICIENT_MEM
Insufficient memory
RSMERR_INSUFFICIENT_RESOURCES
Insufficient resources
RSMERR_BAD_MEM_ALIGNMENT
Address not aligned on page boundary
RSMERR_INTERRUPTED
Operation interrupted by signal
Segment Destruction
int rsm_memseg_export_destroy(rsm_memseg_export_handle_t memseg);
This function deallocates segment and its free resources. All importing processes are forcibly disconnected.
RSMERR_BAD_SEG_HNDL
RSMERR_POLLFD_IN_USE
pollfd in use
