Programming Interfaces Guide
Memory Segment Rebind
The rebind operation releases the current backing store for an export segment. After releasing the current backing store for an export segment, the rebind operation allocates a new backing store. The application must first obtain a new virtual memory allocation for the segment. This operation is transparent to importers of the segment.
Note –
The application has the responsibility of preventing access to segment data until the rebind operation is complete. Retrieving data from a segment during rebinding does not cause a system failure, but the results of such an operation are undefined.
Rebind Segment
int rsm_memseg_export_rebind(rsm_memseg_export_handle_t memseg, void *vaddr, offset_t off, size_t size);
Return Values: Returns 0 if successful. Returns an error value otherwise.
RSMERR_BAD_SEG_HNDL
Invalid segment handle
RSMERR_BAD_LENGTH
Invalid length
RSMERR_BAD_ADDR
Invalid address
RSMERR_REBIND_NOT_ALLOWED
Rebind not allowed
RSMERR_NOT_CREATOR
Not creator of segment
RSMERR_PERM_DENIED
Permission denied
RSMERR_INSUFFICIENT_MEM
Insufficient memory
RSMERR_INSUFFICIENT_RESOURCES
Insufficient resources
RSMERR_INTERRUPTED
Operation interrupted by signal
