POSIX semaphores are much lighter weight than are System V semaphores. A POSIX semaphore structure defines a single semaphore, not an array of up to 25 semaphores.
The POSIX semaphore interfaces are shown below.
Connects to, and optionally creates, a named semaphore
Initializes a semaphore structure (internal to the calling program, so not a named semaphore)
Ends the connection to an open semaphore
Ends the connection to an open semaphore and causes the semaphore to be removed when the last process closes it
Copies the value of the semaphore into the specified integer
Blocks while the semaphore is held by other processes or returns an error if the semaphore is held by another process
Increments the count of the semaphore
