This chapter describes how to create and back up UFS snapshots.
For information on the procedures associated with creating UFS snapshots, see Using UFS Snapshots (Task Map).
For overview information about performing backups, see Chapter 23, Backing Up and Restoring UFS File Systems (Overview).
Task |
Description |
For Instructions |
1. Create a UFS snapshot. |
Create a read-only copy of a file system by using the fssnap command. | |
2. Display UFS snapshot information. |
Identify UFS snapshot information such as the raw snapshot device. | |
3. (Optional) Delete a UFS snapshot. |
Delete a snapshot that is already backed up or no longer needed. | |
4. (Optional) Back up a UFS snapshot. |
Choose one of the following backup methods: |
Create a full backup of a UFS snapshot by using the ufsdump command. | |
Create an incremental backup of a UFS snapshot by using the ufsdump command.
How to Create an Incremental Backup of a UFS Snapshot (ufsdump) |
Back up a UFS snapshot by using the tar command. | |
5. (Optional) Restore data from a UFS snapshot. |
Restore the UFS snapshot the same way as you would restore data by using the ufsrestore command. |
You can use the fssnap command to back up file systems while the file system is mounted. This command to creates a read-only snapshot of a file system. A snapshot is a file system's temporary image that is intended for backup operations.
When the fssnap command is run, it creates a virtual device and a backing-store file. You can back up the virtual device, which looks and acts like a real device, with any of the existing Solaris backup commands. The backing-store file is a bitmap file that contains copies of pre snapshot data that has been modified since the snapshot was taken.
Keep the following key points in mind when specifying backing-store files:
The destination path of the backing store files must have enough free space to hold the file system data. The size of the backing store files vary with the amount of activity on the file system.
The backing store file location must be different from the file system that is being captured in a snapshot.
The backing-store files can reside on any type of file system, including another UFS file system or an NFS file system.
Multiple backing-store files are created when you create a snapshot of a UFS file system that is larger than 512 GB.
Backing-store files are sparse files. The logical size of a sparse file, as reported by the ls command, is not the same as the amount of space that has been allocated to the sparse file, as reported by the du command.
For more information about creating snapshots for a UFS file system larger than 512 GB, see Creating a Multiterabyte UFS Snapshot.
The UFS snapshots feature provides additional availability and convenience for backing up a file system because the file system remains mounted and the system remains in multiuser mode during backups. Then, you can use the tar or cpio commands to back up a UFS snapshot to tape for more permanent storage. If you use the ufsdump command to perform backups, the system should be in single-user mode to keep the file system inactive when you perform backups.
The fssnap command gives administrators of non enterprise-level systems the power of enterprise-level tools, such as Sun StorEdge Instant Image, without the large storage demands.
The UFS snapshots feature is similar to the Instant Image product. Although UFS snapshots can make copies of large file systems, Instant Image is better suited for enterprise-level systems. UFS snapshots is better suited for smaller systems. Instant Image allocates space equal to the size of the entire file system that is being captured. However, the backing-store file that is created by UFS snapshots occupies only as much disk space as needed.
This table describes specific differences between UFS snapshots and Instant Image.
UFS Snapshots |
Sun StorEdge Instant Image |
Size of the backing-store file depends on how much data has changed since the snapshot was taken |
Size of the backing-store file equals the size of the entire file system being copied |
Does not persist across system reboots |
Persists across system reboots |
Works on UFS file systems |
Cannot be used with root (/) or /usr file systems |
Available starting with the Solaris 8 1/01 release |
Part of Sun StorEdge products |
When the UFS snapshot is first created, users of the file system might notice a slight pause. The length of the pause increases with the size of the file system to be captured. While the snapshot is active, users of the file system might notice a slight performance impact when the file system is written to. However, they see no impact when the file system is read.
When you use the fssnap command to create a UFS snapshot, observe how much disk space the backing-store file consumes. The backing-store file initially uses no space, and then it grows quickly, especially on heavily used systems. Make sure that the backing-store file has enough space to expand. Or, limit its size with the -o maxsize=n [k,m,g] option, where n [k,m,g] is the maximum size of the backing-store file.
If the backing-store file runs out of space, the snapshot might delete itself, which causes the backup to fail. Check the /var/adm/messages file for possible snapshot errors.
You can also specify a directory for the backing-store path, which means a backing store file is created in the directory specified. For example, if /var/tmp is specified for the backing-store path, the following backing-store file is created.
/var/tmp/snapshot0 |
If you created one large root (/) file system instead of creating separate file systems for /export/home, /usr, and so on, you will be unable to create a snapshot of those separate file systems. For example, this system does not have a separate file system for /usr as indicated under the Mounted on column:
# df -k /usr Filesystem kbytes used avail capacity Mounted on /dev/dsk/c0t0d0s0 3618177 2190002 1391994 62% / |
If you attempt to create a snapshot for the /usr file system, you will see a message similar to the following:
# fssnap -F ufs -o bs=/snaps/usr.back.file /usr snapshot error: Invalid backing file path |
This message indicates that you cannot have the backing store file on the same file system as the file system being snapped, which is the case for the /usr file system, in this example.
For more information, see the fssnap_ufs(1M) man page.
Creating a multiterabyte UFS snapshot is identical to creating a snapshot for a smaller UFS file system. The only difference is that multiple backing store files are created for each 512 GB of file system space.
Keep the following key points in mind when creating a snapshot for a file system that is larger than 512 GB:
Multiple backing store files are created.
If you specify a backing store file name when the snapshot is created, then the subsequent backing store file names will be interated based on the file name that you specify. The subsequent backing-store files will have the same name, but with the suffixes .2, .3, and so on.
If you only specify a backing store file destination (or directory) and not a backing store file name, then multiple backing store file names will be created and iterated with the suffixes .2, .3, and so on.
The fssnap -i command only reports the first backing store file name even if multiple backing store files have been created. However, the reported backing-store length is the combined sizes of all the backing store files for the snapshot.
After you have backed up the snapshot or you would just like to remove the snapshot, you will have to remove the backing store files manually if you did not use the unlink option when the snapshot was created.
For an example of creating a snapshot for a file system that is larger than 512 GB, see Example 25–2.
For more information, see fssnap_ufs(1M).
Become superuser or assume an equivalent role.
Make sure that the file system has enough disk space for the backing-store file.
# df -k |
Make sure that a backing-store file of the same name and location does not already exist.
# ls /backing-store-file |
Create the UFS snapshot.
# fssnap -F ufs -o bs=/backing-store-file /file-system |
The backing-store file must reside on a different file system than the file system that is being captured using UFS snapshots.
Verify that the snapshot has been created.
# /usr/lib/fs/ufs/fssnap -i /file-system |
The following example shows how to create a snapshot of the /usr file system. The backing-store file is /scratch/usr.back.file. The virtual device is /dev/fssnap/1.
# fssnap -F ufs -o bs=/scratch/usr.back.file /usr /dev/fssnap/1 |
The following example shows how to limit the backing-store file to 500 MB.
# fssnap -F ufs -o maxsize=500m,bs=/scratch/usr.back.file /usr /dev/fssnap/1 |
The following example shows how to create a snapshot of a 1.6 TB UFS file system.
# fssnap -F ufs -o bs=/var/tmp /datab /dev/fssnap/2 # /usr/lib/fs/ufs/fssnap -i /datab Snapshot number : 2 Block Device : /dev/fssnap/2 Raw Device : /dev/rfssnap/2 Mount point : /datab Device state : idle Backing store path : /var/tmp/snapshot3 Backing store size : 0 KB Maximum backing store size : Unlimited Snapshot create time : Mon Jul 12 10:37:50 2010 Copy-on-write granularity : 32 KB |
You can display the current snapshots on the system by using the fssnap -i option. If you specify a file system, you see detailed information about that file system snapshot. If you don't specify a file system, you see information about all of the current UFS snapshots and their corresponding virtual devices.
Use the UFS file system-specific fssnap command to view the extended snapshot information as shown in the following examples.
List all current snapshots.
For example:
# /usr/lib/fs/ufs/fssnap -i Snapshot number : 0 Block Device : /dev/fssnap/0 Raw Device : /dev/rfssnap/0 Mount point : /export/home Device state : idle Backing store path : /var/tmp/snapshot0 Backing store size : 0 KB Maximum backing store size : Unlimited Snapshot create time : Mon Jul 12 10:37:50 2010 Copy-on-write granularity : 32 KB |
Display detailed information about a specific snapshot.
For example:
# /usr/lib/fs/ufs/fssnap -i /export Snapshot number : 1 Block Device : /dev/fssnap/1 Raw Device : /dev/rfssnap/1 Mount point : /export Device state : idle Backing store path : /var/tmp/snapshot1 Backing store size : 0 KB Maximum backing store size : Unlimited Snapshot create time : Mon Jul 12 10:37:50 2010 Copy-on-write granularity : 32 KB |
When you create a UFS snapshot, you can specify that the backing-store file is unlinked. An unlinked backing-store file is removed after the snapshot is deleted. If you don't specify the -o unlink option when you create a UFS snapshot, you must manually delete the backing-store file.
The backing-store file occupies disk space until the snapshot is deleted, whether you use the -o unlink option to remove the backing-store file or you manually delete the file.
You can delete a snapshot either by rebooting the system or by using the fssnap -d command. When you use this command, you must specify the path of the file system that contains the UFS snapshot.
Identify the snapshot to be deleted.
# /usr/lib/fs/ufs/fssnap -i |
Delete the snapshot.
# fssnap -d /file-system Deleted snapshot 1. |
If you did not use the -o unlink option when you created the snapshot, manually delete the backing-store file.
# rm /file-system/backing-store-file |
The following example shows how to delete a snapshot and assumes that the -o unlink option was not used.
# fssnap -i
0 /export/home
1 /export
# fssnap -d /export
Deleted snapshot 1.
# rm /var/tmp/snapshot1
You can create a full backup or an incremental backup of a UFS snapshot. You can use the standard Solaris backup commands to back up a UFS snapshot.
The virtual device that contains the UFS snapshot acts as a standard read-only device. So, you can back up the virtual device as if you were backing up a file system device.
If you are using the ufsdump command to back up a UFS snapshot, you can specify the snapshot name during the backup. See the following procedure for more information.
Identify the UFS snapshot to be backed up.
For example:
# /usr/lib/fs/ufs/fssnap -i /usr Snapshot number : 1 Block Device : /dev/fssnap/1 Raw Device : /dev/rfssnap/1 Mount point : /usr Device state : idle Backing store path : /var/tmp/snapshot2 Backing store size : 544 KB Maximum backing store size : Unlimited Snapshot create time : Mon Jul 12 10:37:50 2010 Copy-on-write granularity : 32 KB |
Back up the UFS snapshot.
# ufsdump 0ucf /dev/rmt/0 /snapshot-name |
For example:
# ufsdump 0ucf /dev/rmt/0 /dev/rfssnap/1 |
Verify that the snapshot has been backed up.
For example:
# ufsrestore tf /dev/rmt/0 |
Backing up a UFS snapshot incrementally means that only the files that have been modified since the last snapshot are backed up. Use the ufsdump command with the N option. This option specifies the file system device name to be inserted into the /etc/dumpdates file for tracking incremental dumps.
The following ufsdump command specifies an embedded fssnap command to create an incremental backup of a file system.
Create an incremental backup of a UFS snapshot.
For example:
# ufsdump 1ufN /dev/rmt/0 /dev/rdsk/c0t1d0s0 `fssnap -F ufs -o raw,bs= /export/scratch,unlink /dev/rdsk/c0t1d0s0` |
In this example, the -o raw option is used to display the name of the raw device instead of the block device. By using this option, you make it easier to embed the fssnap command in commands (such as the ufsdump command) that require the raw device instead.
# ufsrestore ta /dev/rmt/0 |
If you are using the tar command to back up the snapshot, mount the snapshot before backing it up.
Create a mount point for the snapshot.
For example:
# mkdir /backups/home.bkup |
Mount the snapshot.
# mount -F ufs -o ro /dev/fssnap/1 /backups/home.bkup |
Change to the mounted snapshot directory.
# cd /backups/home.bkup |
Back up the snapshot with the tar command.
# tar cvf /dev/rmt/0 . |
The backup created from the virtual device is essentially just a backup of what the original file system looked like when the snapshot was taken. When you restore a file system from the backup, restore as if you had taken the backup directly from the original file system. Such a restore uses the ufsrestore command. For information on using the ufsrestore command to restore a file or file system, see Chapter 26, Restoring UFS Files and File Systems (Tasks).
