System Administration Guide: Devices and File Systems
ProcedureHow to Display System Configuration Information
Use the output of the prtconf and sysdef commands to identify which disk, tape, and DVD devices are connected to the system. The output of these commands displays the driver not attached messages next to the device instances. Because these devices are always being monitored by some system process, the driver not attached message is usually a good indication that no device exists at that device instance.
Use the sysdef command to display system configuration information that include pseudo devices, loadable modules, and selected kernel parameters.
  1. Display system and device configuration information.
    • Display all the devices connected to a system.
      For example, the following prtconf -v output on a SunBlade 1000 identifies the disk devices connected to the system. The detailed disk information is described in the Device Minor Nodes section within the ssd/fp driver section.
      $ /usr/sbin/prtconf -v | more
                  Device Minor Nodes:
                     dev=(118,8)
                        dev_path=/pci@8,600000/SUNW,qlc@4/fp@0,0/ssd@w210000
      2037bde864,0:a
                            spectype=blk type=minor
                            dev_link=/dev/dsk/c0t1d0s0
      2037bde864,0:a,raw
                            spectype=chr type=minor
                            dev_link=/dev/rdsk/c0t1d0s0
                     dev=(118,9)
      2037bde864,0:b
                            dev_link=/dev/dsk/c0t1d0s1
      2037bde864,0:b,raw
    • Display information about one specific device connected to the system.
      For example, the following prtconf output on a SunBlade 1000 displays the ssd instance number for /dev/dsk/c0t1d0s0.
      # prtconf -v /dev/dsk/c0t1d0s0
      ssd, instance #1
    • Display only the devices that are attached to the system.
      # prtconf | grep -v not
    • Display device usage information.
      For example, the following fuser command displays which processes are accessing the /dev/console device.
      # fuser -d /dev/console
      /dev/console:      346o     323o
Example 5–1 Displaying System Configuration Information
The following prtconf output is displayed on a SPARC based system.
# prtconf
System Configuration:  Sun Microsystems  sun4u
Memory size: 512 Megabytes
System Peripherals (Software Nodes):
SUNW,Sun-Blade-1000
    scsi_vhci, instance #0
    packages (driver not attached)
        SUNW,builtin-drivers (driver not attached)
        deblocker (driver not attached)
        disk-label (driver not attached)
        terminal-emulator (driver not attached)
        obp-tftp (driver not attached)
        dropins (driver not attached)
        kbd-translator (driver not attached)
        ufs-file-system (driver not attached)
    chosen (driver not attached)
    openprom (driver not attached)
        client-services (driver not attached)
    options, instance #0
    aliases (driver not attached)
    memory (driver not attached)
    virtual-memory (driver not attached)
    SUNW,UltraSPARC-III, instance #0
    memory-controller, instance #0
    SUNW,UltraSPARC-III, instance #1
    memory-controller, instance #1
    pci, instance #0
        ebus, instance #0
            flashprom (driver not attached)
            bbc (driver not attached)
            ppm, instance #0
            i2c, instance #0
                dimm-fru, instance #0
                dimm-fru, instance #1
                dimm-fru, instance #2
                dimm-fru, instance #3
                nvram, instance #4
                idprom (driver not attached)
            i2c, instance #1
                cpu-fru, instance #5
                temperature, instance #0
                cpu-fru, instance #6
                temperature, instance #1
                fan-control, instance #0
                motherboard-fru, instance #7
                i2c-bridge (driver not attached)
            beep, instance #0
            rtc, instance #0
            gpio (driver not attached)
            pmc (driver not attached)
            floppy (driver not attached)
            parallel (driver not attached)
            serial, instance #0
        network, instance #0
        firewire, instance #0
        usb, instance #0
        scsi (driver not attached)
            disk (driver not attached)
            tape (driver not attached)
    pci, instance #1
        SUNW,qlc, instance #0
            fp (driver not attached)
            fp, instance #1
                ssd, instance #1
                ssd, instance #0 (driver not attached)
                ssd, instance #2 (driver not attached)
                ssd, instance #3 (driver not attached)
                ssd, instance #4 (driver not attached)
                ssd, instance #5 (driver not attached)
                ssd, instance #6 (driver not attached)
    upa, instance #0
        SUNW,ffb, instance #0 (driver not attached)
    ppm, instance #0
    pseudo, instance #0
The following sysdef output is displayed from an x86 based system.
# sysdef
* Hostid
  29f10b4d
* i86pc Configuration
* Devices
+boot (driver not attached)
i86pc-memory (driver not attached)
i86pc-mmu (driver not attached)
delayed-writes (driver not attached)
itu-props (driver not attached)
isa, instance #0
	motherboard (driver not attached)
	pnpADP,1542, instance #0
	asy, instance #0
	asy, instance #1
	lp, instance #0 (driver not attached)
	fdc, instance #0
		fd, instance #0
		fd, instance #1 (driver not attached)
	kd (driver not attached)
	kdmouse (driver not attached)
