The following procedure has been updated for adding a PCIe adapter card. However, the procedure to add an adapter card is the same whether you are using PCI or PCIe.
Become superuser.
Identify the hot-pluggable slot and open latches.
For example, pcie3.
# cfgadm pci Ap_Id Type Receptacle Occupant Condition pcie1 unknown empty unconfigured unknown pcie2 unknown empty unconfigured unknown pcie3 unknown empty unconfigured unknown pcie4 unknown empty unconfigured unknown pcie5 pci-pci/hp connected configured ok pcie6 unknown disconnected unconfigured unknown |
Follow the appropriate instructions in your platform guide to insert a PCI adapter card into the slot.
Determine which slot the PCI adapter card is in after it is inserted.
For example:
# cfgadm pci Ap_Id Type Receptacle Occupant Condition pcie1 unknown empty unconfigured unknown pcie2 unknown empty unconfigured unknown pcie3 unknown disconnected unconfigured unknown pcie4 unknown empty unconfigured unknown pcie5 pci-pci/hp connected configured ok pcie6 unknown disconnected unconfigured unknown |
Connect the power to the slot manually using the cfgadm command. Or, if you have a PCIe adapter card, use the auto-configuration method, such as pressing the slot's Attention Button as defined by your platform guide.
For example:
# cfgadm -c connect pcie3 |
Confirm that the attachment point is connected.
For example:
# cfgadm pci Ap_Id Type Receptacle Occupant Condition pcie1 unknown empty unconfigured unknown pcie2 unknown empty unconfigured unknown pcie3 unknown connected unconfigured unknown pcie4 unknown empty unconfigured unknown pcie5 pci-pci/hp connected configured ok pcie6 unknown disconnected unconfigured unknown |
Configure the PCI adapter card manually by using the cfgadm command as shown below. If using the auto-configuration method, this step should not be necessary. Refer to your platform guide for more information.
For example:
# cfgadm -c configure pcie3 |
Verify the configuration of the PCI adapter card in the slot.
For example:
# cfgadm pci Ap_Id Type Receptacle Occupant Condition pcie1 unknown empty unconfigured unknown pcie2 unknown empty unconfigured unknown pcie3 etherne/hp connected configured unknown pcie5 pci-pci/hp connected configured ok pcie6 unknown disconnected unconfigured unknown |
Configure any supporting software if this device is a new device.
For example, if this device is an Ethernet card, use the ifconfig command to set up the interface.
The auto-configuration method can be enabled or disabled at boot, depending on the platform implementation. Set the auto-configuration method as appropriate for your environment.
