Disks are typically formatted by the manufacturer or reseller. They usually do not need to be reformatted when you install the drive.
A disk must be formatted before you can do the following:
Write data to the disk. However, most disks are already formatted.
Use the Solaris installation utility to install the system.
Formatting a disk is a destructive process because it overwrites data on the disk. For this reason, disks are usually formatted only by the manufacturer or reseller. If you think disk defects are the cause of recurring problems, you can use the format utility to do a surface analysis. However, be careful to use only the commands that do not destroy data.
Become superuser or assume an equivalent role.
# format |
A numbered list of disks is displayed.
Type the number of the disk that you want to check.
Specify disk (enter its number): 0 |
Verify that the disk you chose is formatted by noting the following message:
[disk formatted] |
The following example shows that disk c1t0d0 is formatted.
# format /dev/rdsk/c1*
AVAILABLE DISK SELECTIONS:
0. /dev/rdsk/c1t0d0s0 <SUN18G cyl 7506 alt 2 hd 19 sec 248>
/sbus@2,0/QLGC,isp@2,10000/sd@0,0
1. /dev/rdsk/c1t1d0s0 <SUN18G cyl 7506 alt 2 hd 19 sec 248>
/sbus@2,0/QLGC,isp@2,10000/sd@1,0
2. /dev/rdsk/c1t8d0s0 <SUN18G cyl 7506 alt 2 hd 19 sec 248>
/sbus@2,0/QLGC,isp@2,10000/sd@8,0
3. /dev/rdsk/c1t9d0s0 <SUN18G cyl 7506 alt 2 hd 19 sec 248>
/sbus@2,0/QLGC,isp@2,10000/sd@9,0
selecting /dev/rdsk/c1t0d0s0
[disk formatted]
Invoke the format utility.
# format |
Type the number of the disk that you want to format.
Do not select the system disk. If you format your system disk, you delete the OS and any data on this disk.
To begin formatting the disk, type format at the format> prompt. Confirm the command by typing y.
format> format Ready to format. Formatting cannot be interrupted and takes 23 minutes (estimated). Continue? yes |
Verify that the disk format was successful by noting the following messages:
Beginning format. The current time Tue ABC xx xx:xx:xx xxxx
Formatting...
done
Verifying media...
pass 0 - pattern = 0xc6dec6de
2035/12/18
pass 1 - pattern = 0x6db6db6d
2035/12/18
Total of 0 defective blocks repaired.
Exit the format utility.
format> quit |
The following example shows how to format the disk c0t6d0.
# format
Searching for disks...done
0. c0t0d0 <SUNW18G cyl 7506 alt 2 hd 19 sec 248
/pci@1f,0/pci@1,1/scsi@2/sd@0,0
1. c0t1d0 <FUJITSU MAN3367M SUN36G 1804 43d671f>
/pci@1f,0/pci@1,1/scsi@2/sd@1,0
2. c0t2d0 <FUJITSU MAN3367M SUN36G 1804 43d671f>
/pci@1f,0/pci@1,1/scsi@2/sd@2,0
3. c0t3d0 <FUJITSU MAN3367M SUN36G 1804 43d671f>
/pci@1f,0/pci@1,1/scsi@2/sd@3,0
4. c0t4d0 <FUJITSU MAN3367M SUN36G 1804 43d671f>
/pci@1f,0/pci@1,1/scsi@2/sd@4,0
5. c0t5d0 <FUJITSU MAN3367M SUN36G 1804 43d671f>
/pci@1f,0/pci@1,1/scsi@2/sd@5,0
6. c0t6d0 <FUJITSU MAN3367M SUN36G 1804 43d671f>
/pci@1f,0/pci@1,1/scsi@2/sd@6,0
Specify disk (enter its number): 6
selecting c0t6d0
[disk formatted]
format> format
and takes 332 minutes (estimated). Continue? y
Beginning format. The current time is Mon Jul 12 10:52:10 2010
Formatting...
Verifying media...
format> quit
