System Administration Guide: Devices and File Systems
ProcedureHow to Format a Disk
  1. Become superuser or assume an equivalent role.
  2. Invoke the format utility.
    # format
    A numbered list of disks is displayed.
  3. Type the number of the disk that you want to format.
    Specify disk (enter its number): 0
    Caution – Caution –
    Do not select the system disk. If you format your system disk, you delete the OS and any data on this disk.
  4. To begin formatting the disk, type format at the format> prompt. Confirm the command by typing y.
    format> format
    Ready to format.  Formatting cannot be interrupted
    and takes 23 minutes (estimated). Continue? yes
  5. Verify that the disk format was successful by noting the following messages:
    Beginning format. The current time Tue ABC xx xx:xx:xx xxxx
    Formatting...
    done
    Verifying media...
            pass 0 - pattern = 0xc6dec6de
       2035/12/18
            pass 1 - pattern = 0x6db6db6d
       2035/12/18
    Total of 0 defective blocks repaired.
  6. Exit the format utility.
    format> quit
Example 11–3 Formatting a Disk
The following example shows how to format the disk c0t6d0.
# format
Searching for disks...done
AVAILABLE DISK SELECTIONS:
       0. c0t0d0 <SUNW18G cyl 7506 alt 2 hd 19 sec 248
          /pci@1f,0/pci@1,1/scsi@2/sd@0,0
       1. c0t1d0 <FUJITSU  MAN3367M SUN36G  1804 43d671f>
          /pci@1f,0/pci@1,1/scsi@2/sd@1,0
       2. c0t2d0 <FUJITSU  MAN3367M SUN36G  1804 43d671f>
          /pci@1f,0/pci@1,1/scsi@2/sd@2,0
       3. c0t3d0 <FUJITSU  MAN3367M SUN36G  1804 43d671f>
          /pci@1f,0/pci@1,1/scsi@2/sd@3,0
       4. c0t4d0 <FUJITSU  MAN3367M SUN36G  1804 43d671f>
          /pci@1f,0/pci@1,1/scsi@2/sd@4,0
       5. c0t5d0 <FUJITSU  MAN3367M SUN36G  1804 43d671f>
          /pci@1f,0/pci@1,1/scsi@2/sd@5,0
       6. c0t6d0 <FUJITSU  MAN3367M SUN36G  1804 43d671f>
          /pci@1f,0/pci@1,1/scsi@2/sd@6,0
Specify disk (enter its number): 6
selecting c0t6d0
[disk formatted]
format> format
and takes 332 minutes (estimated). Continue? y
Beginning format. The current time is Mon Jul 12 10:52:10 2010
Formatting...
Verifying media...
format> quit
