Sometimes, a power or system failure causes a disk's label to become unrecognizable. A corrupted disk label doesn't always mean that the slice information or the disk's data must be re-created or restored.
The first step to recovering a corrupted disk label is to label the disk with the correct geometry and disk type information. You can complete this step through the normal disk labeling method, by using either automatic configuration or manual disk type specification.
If the format utility recognizes the disk type, the next step is to search for a backup label to label the disk. Labeling the disk with the backup label labels the disk with the correct partitioning information, the disk type, and disk geometry.
Boot the system to single-user mode.
If necessary, boot the system from a local Solaris DVD or the network in single-user mode to access the disk.
See Chapter 12, Booting an Oracle Solaris System (Tasks), in System Administration Guide: Basic Administration or Booting an x86 Based System by Using GRUB (Task Map) in System Administration Guide: Basic Administration for information on booting the system.
# format |
The format utility attempts to automatically configure any unlabeled SCSI disk. If the format utility is able to configure the unlabeled and corrupted disk, it will display this message:
cwtxdy: configured with capacity of abcMB |
The format utility then displays a numbered list of disks on the system.
Type the number of the disk that you need to recover.
Specify disk (enter its number): 1 |
Select one of the following to determine how to label the disk.
If the disk was configured successfully, follow Steps 5 and 6. Then go to step 12.
If the disk was not configured successfully, follow Steps 7–11. Then go to step 12.
Search for the backup label.
format> verify Warning: Could not read primary label. Warning: Check the current partitioning and 'label' the disk or use the 'backup' command. Backup label contents: Volume name = < > ascii name = <SUN1.05 cyl 2036 alt 2 hd 14 sec 72> pcyl = 2038 ncyl = 2036 acyl = 2 nhead = 14 nsect = 72 Part Tag Flag Cylinders Size Blocks 0 root wm 0 - 300 148.15MB (301/0/0) 303408 1 swap wu 301 - 524 110.25MB (224/0/0) 225792 2 backup wm 0 - 2035 1002.09MB (2036/0/0) 2052288 3 unassigned wm 0 0 (0/0/0) 0 4 unassigned wm 0 0 (0/0/0) 0 5 unassigned wm 0 0 (0/0/0) 0 6 usr wm 525 - 2035 743.70MB (1511/0/0) 1523088 7 unassigned wm 0 0 (0/0/0) 0 |
If the format utility was able to find a backup label and the backup label contents appear satisfactory, use the backup command to label the disk with the backup label.
format> backup Disk has a primary label, still continue? y Searching for backup labels...found. Restoring primary label |
The disk label has been recovered. Go to Step 12.
If the format utility was not able to automatically configure the disk, specify the disk type by using the type command.
format> type |
The Available Drives Type menu is displayed.
Select 0 to automatically configure the disk. Or, select a disk type from the list of possible disk types.
Specify disk type (enter its number)[12]: 12 |
If the disk was successfully configured, reply with no when the format utility asks if you want to label the disk.
Disk not labeled. Label it now? no |
Use the verify command to search for backup labels.
format> verify Warning: Could not read primary label. Warning: Check the current partitioning and 'label' the disk or use the 'backup' command. . . . |
Exit the format utility.
format> q |
Verify the file systems on the recovered disk by using the fsck command.
For information on using the fsck command, see Chapter 21, Checking UFS File System Consistency (Tasks).
