System Administration Guide: Devices and File Systems
ProcedureSPARC: How to Create Disk Slices and Label a Disk
  1. Become superuser or assume an equivalent role.
  2. Invoke the format utility.
    # format
    A numbered list of available disks is displayed. For more information, see format(1M).
  3. Type the number of the disk that you want to repartition.
    Specify disk (enter its number): disk-number
    disk-number is the number of the disk that you want to repartition.
  4. Select the partition menu.
    format> partition
  5. Display the current partition (slice) table.
    partition> print
  6. Start the modification process.
    partition> modify
  7. Set the disk to all free hog.
    Choose base (enter number) [0]?1
    For more information about the free hog slice, see Using the Free Hog Slice.
  8. Create a new partition table by answering y when prompted to continue.
    Do you wish to continue creating a new partition table based on
    above table[yes]? y
  9. Identify the free hog partition (slice) and the sizes of the slices when prompted.
    When adding a system disk, you must set up slices for:
    • root (slice 0) and swap (slice 1)
    • /usr (slice 6)
    After you identify the slices, the new partition table is displayed.
    For an example of creating disk slices, see Example 12–1.
  10. Make the displayed partition table the current partition table by answering y when prompted.
    Okay to make this the current partition table[yes]? y
    If you do not want the current partition table and you want to change it, answer no and go to Step 6.
  11. Name the partition table.
    Enter table name (remember quotes): "partition-name"
    where partition-name is the name for the new partition table.
  12. Label the disk with the new partition table after you have finished allocating slices on the new disk.
    Ready to label disk, continue? yes
  13. Quit the partition menu.
    partition> q
  14. Verify the disk label.
    format> verify
  15. Exit the format utility.
    format> q
Example 12–1 SPARC: Creating Disk Slices and Labeling a System Disk
The following example shows the format utility being used to divide a 18-GB disk into three slices: one slice for the root (/) file system, one slice for the swap area, and one slice for the /usr file system.
# format
AVAILABLE DISK SELECTIONS:
       0. /dev/rdsk/c1t0d0s0 <SUN18G cyl 7506 alt 2 hd 19 sec 248>
          /sbus@2,0/QLGC,isp@2,10000/sd@0,0
       1. /dev/rdsk/c1t1d0s0 <SUN18G cyl 7506 alt 2 hd 19 sec 248>
          /sbus@2,0/QLGC,isp@2,10000/sd@1,0
       2. /dev/rdsk/c1t8d0s0 <SUN18G cyl 7506 alt 2 hd 19 sec 248>
          /sbus@2,0/QLGC,isp@2,10000/sd@8,0
       3. /dev/rdsk/c1t9d0s0 <SUN18G cyl 7506 alt 2 hd 19 sec 248>
          /sbus@2,0/QLGC,isp@2,10000/sd@9,0
Specify disk (enter its number): 0
selecting c1t0d0
[disk formatted]
format> partition
partition> print
partition> modify
Select partitioning base:
	0. Current partition table (original)
	1. All Free Hog
Part      Tag    Flag     Cylinders        Size            Blocks
  0       root    wm       0               0         (0/0/0)           0
  1       swap    wu       0               0         (0/0/0)           0
  2     backup    wu       0 - 7505       16.86GB    (7506/0/0) 35368272
  3 unassigned    wm       0               0         (0/0/0)           0
  4 unassigned    wm       0               0         (0/0/0)           0
  5 unassigned    wm       0               0         (0/0/0)           0
  6        usr    wm       0               0         (0/0/0)           0
  7 unassigned    wm       0               0         (0/0/0)           0
Choose base (enter number) [0]? 1
table based on above table[yes]? yes
Free Hog partition[6]? 6
Enter size of partition '0' [0b, 0c, 0.00mb, 0.00gb]: 4gb
Enter size of partition '1' [0b, 0c, 0.00mb, 0.00gb]: 4gb
Enter size of partition '3' [0b, 0c, 0.00mb, 0.00gb]:
Enter size of partition '4' [0b, 0c, 0.00mb, 0.00gb]:
Enter size of partition '5' [0b, 0c, 0.00mb, 0.00gb]:
Enter size of partition '7' [0b, 0c, 0.00mb, 0.00gb]:
  0       root    wm       0 - 1780        4.00GB    (1781/0/0)  8392072
  1       swap    wu    1781 - 3561        4.00GB    (1781/0/0)  8392072
  6        usr    wm    3562 - 7505        8.86GB    (3944/0/0) 18584128
Okay to make this the current partition table[yes]? yes
Enter table name (remember quotes): "disk0"
partition> quit
format> verify
format> quit
Example 12–2 SPARC: Creating Disk Slices and Labeling a Secondary Disk
The following example shows the format utility being used to divide a 18-GB disk into one slice for the /export/home file system.
# format /dev/rdsk/c1*
Specify disk (enter its number): 1
selecting c1t1d0
[disk formatted]
format> partition
partition> print
partition> modify
	1. All Free Hog
Free Hog partition[6]? 7
Enter size of partition '6' [0b, 0c, 0.00mb, 0.00gb]:
  7 unassigned    wm       0 - 7505       16.86GB    (7506/0/0) 35368272
Enter table name (remember quotes): "home"
partition> q
format> verify
format> q
The following example shows how to use the format utility to divide a 1.15 terabyte disk with an EFI label into three slices.
# format
partition> modify
        1. All Free Hog
Part      Tag    Flag     First Sector          Size          Last Sector
  0       root    wm                 0            0                0
  1        usr    wm                 0            0                0
  2 unassigned    wm                 0            0                0
  3 unassigned    wm                 0            0                0
  4 unassigned    wm                 0            0                0
  5 unassigned    wm                 0            0                0
  6        usr    wm                 0            0                0
  8   reserved    wm        2576924638         8.00MB           2576941021
Free Hog partition[6]? 4
Enter size of partition 0 [0b, 34e, 0mb, 0gb, 0tb]:
Enter size of partition 1 [0b, 34e, 0mb, 0gb, 0tb]:
Enter size of partition 2 [0b, 34e, 0mb, 0gb, 0tb]: 400gb
Enter size of partition 3 [0b, 838860834e, 0mb, 0gb, 0tb]: 400gb
Enter size of partition 5 [0b, 1677721634e, 0mb, 0gb, 0tb]:
Enter size of partition 6 [0b, 1677721634e, 0mb, 0gb, 0tb]:
  0 unassigned    wm                 0            0                0
  1 unassigned    wm                 0            0                0
  2        usr    wm                34       400.00GB           838860833
  3        usr    wm         838860834       400.00GB           1677721633
  4        usr    wm        1677721634       428.77GB           2576924637
  6 unassigned    wm                 0            0                0
partition> q
After You Create Disk Slices and Label a Disk ...
After you create disk slices and label the disk, you can create file systems on the disk. Go to SPARC: How to Create a UFS File System.
