 How to Display Packed Files Information
How to Display Packed Files InformationDisplay packed files information.
| $ cachefspack -i[v] cached-filename-or-directory |
Specifies that you want to view information about your packed files.
Is the verbose option.
Specifies the name of the file or directory for which to display information.
The following example shows that the doc_file file has been successfully packed.
| $ cachefspack -i doc_file cachefspack: file doc_file marked packed YES, packed YES |
In the following example, the /data/abc directory contains the bin subdirectory. The bin subdirectory has three files: big, medium, and small. Although the big and small files are specified to be packed, they are not. The medium file is successfully packed.
| $ cd /data/abc $ cachefspack -i bin . . . cachefspack: file /bin/big marked packed YES, packed NO cachefspack: file /bin/medium marked packed YES, packed YES cachefspack: file /bin/small marked packed YES, packed NO . . . |
If you use the -iv options together, you get additional information as to whether the file or directory specified has been flushed from the cache. For example:
| $ cd /data/bin FSCACHEPACK-4$ cachefspack -iv bin . . . cachefspack: file /bin/big marked packed YES, packed NO, nocache YES cachefspack: file /bin/medium marked packed YES, packed YES, nocache NO cachefspack: file /bin/small marked packed YES, packed NO nocache NO . . . |
The last line of this example shows that the directory contents have not been flushed from the cache.
