For general use, the CacheFS software operates automatically after it is set up, without requiring any action from the user. Files are cached on a most recently used basis. With the packing feature, you can take a more active role in managing your cache by ensuring that certain files or directories are always updated in the cache.
You can specify files and directories to be loaded in the cache by using the cachefspack command. This command ensures that current copies of these files are available in the cache.
The packing list contains the names of specific files and directories. The packing list can also contain other packing lists. This feature saves you from having to specify individual files and directories when you have many items to pack in your cache.
You can print out a brief help summary of all the cachefspack options by using the -h option as follows:
$ cachefspack -h Must select 1 and only 1 of the following 5 options -d Display selected filenames -i Display selected filenames packing status -p Pack selected filenames -u Unpack selected filenames -U Unpack all files in directory 'dir' -f Specify input file containing rules -h Print usage information -r Interpret strings in LIST rules as regular expressions -s Strip './' from the beginning of a pattern name -v Verbose option files - a list of filenames to be packed/unpacked |
$ cachefspack -p filename |
Specifies that you want the file or files to be packed. This option is also the default.
Specifies the name of the file or directory you want packed in the cache. When you specify a directory, all of its subdirectories are also packed. For more information, see cachefspack(1M).
The following example shows the projects file being packed in the cache.
$ cachefspack -p projects |
The following example shows three files being packed in the cache.
$ cachefspack -p projects updates master_plan |
The following example shows a directory being packed in the cache.
$ cachefspack -p /data/abc/bin |
Display packed files information.
$ cachefspack -i[v] cached-filename-or-directory |
Specifies that you want to view information about your packed files.
Is the verbose option.
Specifies the name of the file or directory for which to display information.
The following example shows that the doc_file file has been successfully packed.
$ cachefspack -i doc_file cachefspack: file doc_file marked packed YES, packed YES |
In the following example, the /data/abc directory contains the bin subdirectory. The bin subdirectory has three files: big, medium, and small. Although the big and small files are specified to be packed, they are not. The medium file is successfully packed.
$ cd /data/abc $ cachefspack -i bin . . . cachefspack: file /bin/big marked packed YES, packed NO cachefspack: file /bin/medium marked packed YES, packed YES cachefspack: file /bin/small marked packed YES, packed NO . . . |
If you use the -iv options together, you get additional information as to whether the file or directory specified has been flushed from the cache. For example:
$ cd /data/bin FSCACHEPACK-4$ cachefspack -iv bin . . . cachefspack: file /bin/big marked packed YES, packed NO, nocache YES cachefspack: file /bin/medium marked packed YES, packed YES, nocache NO cachefspack: file /bin/small marked packed YES, packed NO nocache NO . . . |
The last line of this example shows that the directory contents have not been flushed from the cache.
One feature of the cachefspack command is the ability to create packing lists.
A packing list contains files or directories to be packed in the cache. If a directory is in the packing list, all of its subdirectories and files will also be packed.
This feature saves the time of having to specify each individual file that you want packed in the cache.
Create a packing list file by using vi.
The packing list file format uses the same format as the filesync command. For more information, see filesync(1).
Two packing list features are the following:
You can identify files in the packing list as regular expressions rather than literal file names so that you don't have to specify each individual file name.
You can pack files from a shared directory by ensuring that you pack only those files that you own.
For more information on using these features, see cachefspack(1M).
The following example shows the contents of a packing list file.
BASE /home/ignatz LIST plans LIST docs IGNORE *.ps |
The path identified with the BASE statement is the directory where you have items you want to pack.
The two LIST statements identify specific files within that directory to pack.
The IGNORE statement identifies the file type of .ps, which you do not want to pack.
Pack files in the packing list.
$ cachefspack -f packing-list |
Specifies that you want to use a packing list.
Specifies the name of the packing list.
This example uses the list.pkg file as the packing list for the cachefspack command.
$ cachefspack -f list.pkg |
You might need to remove, or unpack, a file from the cache. Perhaps you have some files or directories that have a higher priority than others, so you need to unpack the less critical files. For example, you finished up a project and have archived the files that are associated with that project. You are now working on a new project, and therefore, a new set of files.
Unpack files or packing lists from the cache.
$ cachefspack -u filename | -U cache-directory |
Specifies that you want the file or files unpacked. You must specify a file name with this option.
Specifies the name of the file or packing list that you want unpacked in the cache.
Specifies that you want to unpack all files in the cache.
The following example shows the file /data/abc/bin/big being unpacked from the cache.
$ cachefspack -u /data/abc/bin/big |
The following example shows three files being unpacked from the cache.
$ cd /data/abc/bin/big $ cachefspack -u big small medium |
The following example shows how to unpack a packing list. A packing list is a file that contains the path to a directory of files:
$ cachefspack -uf list.pkg |
The following example uses the -U option to specify that all files in a cache directory being unpacked.
$ cachefspack -U /local/mycache |
You cannot unpack a cache that does not have at least one file system mounted. With the -U option, if you specify a cache that does not contain mounted file systems, output similar to the following is displayed:
$ cachefspack -U /local/mycache cachefspack: Could not unpack cache /local/mycache, no mounted filesystems in the cache. |
You might see the following error messages when you use the cachefspack command.
cachefspack: pathname - can't open directory: permission denied |
You might not have the correct permissions to access the file or directory.
Set the correct permissions.
cachefspack: pathname - can't open directory: no such file or directory |
You might not have specified the correct file or directory.
Check for a possible typo.
cachefspack: pathname - can't open directory: stale NFS file handle |
The file or directory might have been moved or deleted from the server at the time you attempted to access it.
Verify that the file or directory on the server is still accessible.
cachefspack: pathname - can't open directory: interrupted system call |
You might have inadvertently pressed Control-C while issuing the command.
Reissue the command.
cachefspack: pathname - can't open directory: I/O error |
You might have a hardware problem.
Check your hardware connections.
cachefspack: error opening dir |
You might not have specified the correct file or directory. The path identified after the BASE command in the file format could be a file and not a directory. The path specified must be a directory.
Check for a possible typo. Check the path identified after the BASE command in your file format. Ensure that the path identifies a directory, not a file.
cachefspack: unable to get shared objects |
The executable might be corrupt or in a format that is not recognizable.
Replace the executable.
cachefspack: filename - can't pack file: permission denied |
cachefspack: filename - can't pack file: no such file or directory |
cachefspack: filename- can't pack file: stale NFS file handle |
cachefspack: filename- can't pack file: interrupted system call |
cachefspack: filename- can't pack file: I/O error |
cachefspack: filename- can't pack file: no space left on device. |
The cache is out of disk space.
You need to increase the size of the cache by increasing disk space.
cachefspack: filename - can't unpack file: permission denied |
cachefspack: filename - can't unpack file: no such file or directory |
cachefspack: filename- can't unpack file: stale NFS file handle |
cachefspack: filename- can't unpack file: interrupted system call |
cachefspack: filename- can't unpack file I/O error |
cachefspack: only one `d', `i', `p', or `u' option allowed |
You specified more than one of these options in a command session.
Select one option for the command session.
cachefspack: can't find environment variable. |
You forgot to set a corresponding environment variable to match the $ in your configuration file.
Define the environment variable in the proper location.
cachefspack: skipping LIST command - no active base |
A LIST command is present in your configuration file but has no corresponding BASE command.
Define the BASE command.
