System Administration Guide: Devices and File Systems
ProcedureHow to Create and Mount a TMPFS File System
  1. Become superuser or assume an equivalent role.
  2. Create the directory that you want to mount as the TMPFS file system, if necessary.
    # mkdir /mount-point
    where mount-point is the directory on which the TMPFS file system is mounted.
  3. Mount the TMPFS file system.
    # mount -F tmpfs [-o size=number]  swap mount-point
    -o size=number
    Specifies the size limit of the TMPFS file system in MB.
    mount-point
    Specifies the directory on which the TMPFS file system is mounted.
    To set up the system to automatically mount a TMPFS file system at boot time, see Example 17–3.
  4. Verify that the TMPFS file system has been created.
    # mount -v
Example 17–2 Creating and Mounting a TMPFS File System
The following example shows how to create, mount, and limit the size of the TMPFS file system, /export/reports, to 50 MB.
# mkdir /export/reports
# chmod 777 /export/reports
# mount -F tmpfs -o size=50m swap /export/reports
# mount -v
Example 17–3 Mounting a TMPFS File System at Boot Time
You can set up the system to automatically mount a TMPFS file system at boot time by adding an /etc/vfstab entry. The following example shows an entry in the /etc/vfstab file that mounts /export/test as a TMPFS file system at boot time. Because the size=number option is not specified, the size of the TMPFS file system on /export/test is limited only by the available system resources.
swap - /export/test  tmpfs   -  yes  -
For more information on the /etc/vfstab file, see Field Descriptions for the /etc/vfstab File.
