System Administration Guide: Devices and File Systems
Procedurex86: How to Mount a PCFS (DOS) File System From a Hard Disk (mount Command)
Use the following procedure to mount a PCFS (DOS) file system from a hard disk.
  1. Become superuser or assume an equivalent role.
  2. Create a mount point for the file system to be mounted, if necessary.
    # mkdir /mount-point
    There must be a mount point on the local system to mount a file system. A mount point is a directory to which the mounted file system is attached.
  3. Mount the PCFS file system.
    # mount -F pcfs [-o rw | ro] /dev/dsk/device-name:logical-drive /mount-point
    -o rw | ro
    Specifies that you can mount a PCFS file system read/write (rw) or read-only (ro). If you do not specify this option, the default is rw.
    Specifies the device name of the whole disk (for example, /dev/dsk/c0t0d0p0).
    logical-drive
    Specifies either the DOS logical drive letter (c through z) or a drive number (1 through 24). Drive c is equivalent to drive 1 and represents the primary DOS slice on the drive. All other letters or numbers represent DOS logical drives within the extended DOS slice.
    /mount-point
    Specifies the directory on which to mount the file system.
    Note that the device-name and logical-drive must be separated by a colon.
Example 18–8 x86: Mounting a PCFS (DOS) File System From a Hard Disk (mount Command)
The following example shows how to mount the logical drive in the primary DOS slice on the /pcfs/c directory.
# mount -F pcfs /dev/dsk/c0t0d0p0:c /pcfs/c
The following example shows how to mount read-only the first logical drive in the extended DOS slice on the /mnt directory.
# mount -F pcfs -o ro /dev/dsk/c0t0d0p0:2 /mnt
