System Administration Guide: Devices and File Systems
The Virtual File System Table
Manually mounting file systems every time you wanted to access them would be a very time-consuming and error-prone. To avoid these problems, the virtual file system table (the /etc/vfstab file) provides a list of file systems and information on how to mount them.
The /etc/vfstab file provides two important features:
A default /etc/vfstab file is created when you install a system, depending on the selections during installation. However, you can edit the /etc/vfstab file on a system whenever you want. To add an entry, the information you need to specify is as follows:
The following is an example of an /etc/vfstab file for a system that runs a UFS root file system. Comment lines begin with #. This example shows an /etc/vfstab file for a system with two disks (c0t0d0 and c0t3d0).
$ more /etc/vfstab
#device           device              mount            FS      fsck    mount   mount
#to mount         to fsck             point            type    pass    at boot options
fd                 -                  /dev/fd          fd      -       no      -
/proc              -                  /proc            proc    -       no      -
/dev/dsk/c0t0d0s1  -                  -                swap    -       no      -
/dev/dsk/c0t0d0s0  /dev/rdsk/c0t0d0s0 /                ufs     1       no      -
/dev/dsk/c0t0d0s6  /dev/rdsk/c0t0d0s6 /usr             ufs     1       no      -
/dev/dsk/c0t0d0s7  /dev/rdsk/c0t0d0s7 /export/home     ufs     2       yes     -
/dev/dsk/c0t0d0s5  /dev/rdsk/c0t0d0s5 /opt             ufs     2       yes     -
/devices           -                  /devices         devfs   -       no      -
sharefs            -                  /etc/dfs/sharetabsharefs -       no      -
ctfs               -                  /system/contract ctfs    -       no      -
objfs              -                  /system/object   objfs   -       no      -
swap               -                  /tmp             tmpfs   -       yes     -
In this example, root (/) and /usr, the mount at boot field value is specified as no. These file systems are mounted by the kernel as part of the boot sequence before the mountall command is run.
The following vfstab example if from a system that runs a ZFS root file system.
# cat /etc/vfstab
/dev/zvol/dsk/rpool/swap -      -               swap    -       no      -
ZFS file systems are mounted automatically by the SMF service at boot time. You can mount ZFS file systems from the vfstab by using the legacy mount feature. For more information, see Oracle Solaris ZFS Administration Guide.
For descriptions of each /etc/vfstab field and information on how to edit and use the file, see Chapter 18, Mounting and Unmounting File Systems (Tasks).
