System Administration Guide: Devices and File Systems
Default Solaris File Systems
The ZFS or UFS file system is hierarchical, starting with the root directory (/) and continuing downwards through a number of directories. The Solaris installation process enables you to install a default set of directories and uses a set of conventions to group similar types of files together.
For a description of the contents of Solaris file systems and directories, see filesystem(5).
The following table provides a summary of the default Solaris file systems.
Table 16–2 The Default Solaris File Systems
File System or Directory
File System Type
Description
root (/)
UFS or ZFS
The top of the hierarchical file tree. The root (/) directory contains the directories and files that are critical for system operation, such as the kernel, the device drivers, and the programs used to boot the system. The root (/) directory also contains the mount point directories where local and remote file systems can be attached to the file tree.
/usr
UFS or ZFS
System files and directories that can be shared with other users. Files that run only on certain types of systems are in the /usr file system or directory (for example, SPARC executables). Files that can be used on all types of systems, such as the man pages, might be placed in the /usr/share directory.
/export/home or /home
NFS, UFS, or ZFS
The mount point for user home directories, which store user work files. By default, the /home directory is an automounted file system. On stand-alone systems, the /home directory might be a UFS file system or a ZFS file system.
/var
UFS or ZFS
System files and directories that are likely to change or grow over the life of the local system. These include system logs, such as vi and ex backup files.
/opt
NFS, UFS or ZFS
Optional mount point for third-party software. On some systems, the /opt directory might be a UFS file system or ZFS file system.
/tmp
TMPFS
Temporary files, which are removed each time the system is booted or the /tmp file system is unmounted.
/proc
PROCFS
A list of active processes, by process number.
/etc/mnttab
MNTFS
A virtual file system that provides read-only access to the table of mounted file systems for the local system.
/var/run
TMPFS
A memory-based file system for storing temporary files that are not needed after the system is booted.
/system/contract
CTFS
A virtual file system that maintains contract information.
/system/object
OBJFS
A virtual file system that is used by debuggers to access information about kernel symbols without having to access the kernel directly.
The root (/) and /usr file systems are required to run a system. Some of the most basic commands in the /usr file system (like mount) are also included in the root (/) file system. As such, they are available when the system boots or is in single-user mode, and /usr is not mounted. For more detailed information on the default directories for the root (/) and /usr file systems, see Chapter 22, UFS File System (Reference).
