The following task map describes the tasks for managing removable media.
Task |
Description |
For Instructions |
1. Load media. |
Insert the diskette into the drive and type the volcheck command. | |
2. (Optional) Format the diskette. |
Format diskette. | |
3. (Optional) Add a UFS or PCFS file system. |
Add a UFS or PCFS file system to use the media for transferring files. | |
Add a UFS or UDFS file system to a DVD-RAM device. | ||
4. (Optional) Check the media. |
Verify the integrity of the file system on the media. | |
5. (Optional) Repair bad blocks on the media. |
Repair any bad blocks on the media, if necessary. | |
6. (Optional) Apply read or write and password protection. |
Apply read or write protection or password protection on the media, if necessary. |
How to Enable or Disable Write Protection on Removable Media |
