Solaris 10 Installation Guide: Network-Based Installations
Chapter 5 Gathering Information Before Installation or Upgrade (Planning)
This chapter contains checklists to help you gather all of the information that you need to install or upgrade your system.
Checklist for Installation
Use the following checklist to gather the information that you need to install the Solaris OS. You do not need to gather all of the information that is requested on the worksheet. You only need to collect the information that applies to your system.
Table 5–1 Installation Checklist
Information for Installation
Description or Example
Answer — Defaults are noted with an asterisk (*)
Network connection
Is the system connected to a network?
Networked/Non-networked
DHCP
Can the system use Dynamic Host Configuration Protocol (DHCP) to configure its network interfaces?
DHCP provides the network parameters that are necessary for installation.
Yes/No*
If you are not using DHCP, note the network address.
IP Address
If you are not using DHCP, supply the IP address for the system.
Example: 172.31.255.255
To find this information on a running system, type the following command.
# ypmatch host-name hosts
Subnet
If you are not using DHCP, is the system part of a subnet?
If yes, what is the netmask of the subnet?
Example: 255.255.255.0
# more /etc/netmasks
IPv6
Do you want to enable IPv6 on this machine?
IPv6 is a part of the TCP/IP Internet protocol that facilitates IP addressing by adding better security and increasing Internet addresses.
Yes/No*
Host Name
Host name that you choose for the system.
# uname -n
Kerberos
Do you want to configure Kerberos security on this machine?
If yes, gather this information:
Yes/No*
Default Realm:
Administration Server:
First KDC:
(Optional) Additional KDCs:
The Kerberos service is a client-server architecture that provides secure transactions over networks.
If the system uses a name service, provide the following information.
Name Service
Which name service should this system use?
# cat /etc/nsswitch.conf
A naming service stores information in a central place, which enables users, machines, and applications to communicate across the network. Examples of information that is stored are host names and addresses or user names and passwords.
NIS+/NIS/DNS/ LDAP/None
Domain Name
Provide the name of the domain in which the system resides.
# domainname
NIS+ and NIS
Do you want to specify a name server or let the installation program find one?
If you want to specify a name server, provide the following information.
Specify One/Find One*
Server's host name:
  • For NIS clients, type the following command to display the server's host name.
    # ypwhich
  • For NIS+ clients, type the following command to display the server's host name.
    # nisping
Server's IP Address:
  • For NIS clients, type the following command to display the server's IP address.
    # ypmatch nameserver-name hosts
  • For NIS+ clients, type the following command to display the server's IP address.
    # nismatch nameserver-name hosts.org_dir
Network Information Service (NIS) makes network administration more manageable by providing centralized control over a variety of network information, such as machine names and addresses.
DNS
Provide IP addresses for the DNS server. You must enter at least one IP address, but you can enter up to three addresses.
To display the server's IP address, type the following command.
# getent ipnodes dns
You can enter a list of domains to search when a DNS query is made.
Search Domain:
Search Domain:
Search Domain:
The domain name system (DNS) is the name service that the Internet provides for TCP/IP networks. DNS provides host names to the IP address service. DNS simplifies communication by using machine names instead of numerical IP addresses. DNS also serves as a database for mail administration.
LDAP
Provide the following information about your LDAP profile.
Profile Name:
Profile Server:
If you specify a proxy credential level in your LDAP profile, gather this information.
Proxy-bind distinguished name:
Proxy-bind password:
Lightweight Directory Access Protocol (LDAP) defines a relatively simple protocol for updating and searching directories that are running over TCP/IP.
Default Route
Do you want to specify a default route IP address or let the Solaris installation program find one?
The default route provides a bridge that forwards traffic between two physical networks. An IP address is a unique number that identifies each host on a network.
You have the following choices:
  • You can specify the IP address. An /etc/defaultrouter file is created with the specified IP address. When the system is rebooted, the specified IP address becomes the default route.
  • You can let the Solaris installation program detect an IP address. However, the system must be on a subnet that has a router that advertises itself by using the ICMP router discovery protocol. If you are using the command-line interface, the software detects an IP address when the system is booted.
  • You can choose None if you do not have a router or do not want the software to detect an IP address at this time. The software automatically tries to detect an IP address on reboot.
Detect one*/Specify one/None
Time Zone
How do you want to specify your default time zone?
Geographic region*
Offset from GMT
Time zone file
Root Password
Provide the root password for the system.
Locales
For which geographic regions do you want to install support?
SPARC: Power Management (only available on SPARC systems that support Power Management)
Do you want to use Power Management?
Note –
If your system has Energy Star version 3 or later, you are not prompted for this information.
Yes*/No
Automatic reboot or CD/DVD ejection
Reboot automatically after software installation?
Eject CD/DVD automatically after software installation?
Yes*/No
Yes*/No
Default or Custom Install
Do you want to perform a default installation, or customize the installation?
  • Select Default installation to format the entire hard disk and install a preselected set of software.
  • Select Custom installation to modify the hard disk layout and select the software that you want to install.
Note –
The text installer does not prompt you to select a Default or Custom Installation. To perform a default installation, accept the default values that are provided in the text installer. To perform a custom installation, edit the values in the text installer screens.
Default installation*/Custom installation
Software Group
Which Solaris Software Group do you want to install?
Entire Plus OEM
Entire*
Developer
End User
Core
Reduced Networking
Custom Package Selection
Do you want to add or remove software packages from the Solaris Software Group that you install?
Note –
When you select which packages to add or remove, you need to know about software dependencies and how Solaris software is packaged.
Select Disks
On which disks do you want to install the Solaris software?
Example: c0t0d0
x86: fdisk partitioning
Do you want to create, delete, or modify a Solaris fdisk partition?
Each disk that is selected for file system layout must have a Solaris fdisk partition.
If your system currently has a service partition, the Solaris installation program preserves the service partition by default. If you do not want to preserve the service partition, you must customize the fdisk partitions. For more information about preserving a service partition, see Default Boot-Disk Partition Layout Preserves the Service Partition.
Select Disks for fdisk Partition Customization?
Yes/No*
Customize fdisk partitions?
Yes/No*
Preserve Data
Do you want to preserve any data that exists on the disks where you are installing the Solaris software?
Yes/No*
Auto-layout File Systems
Do you want the installation program to automatically lay out file systems on your disks?
If yes, which file systems should be used for auto-layout?
Example: /, /opt, /var
If no, you must provide file system configuration information.
Note –
The Solaris installation GUI lays out file systems automatically by default.
Yes*/No
Mount Remote File Systems
Does this system need to access software on another file system?
If yes, provide the following information about the remote file system.
Yes/No*
Server:
IP Address:
Remote File System:
Local Mount Point:
If you are installing through a tip line, follow these instructions.
Ensure that your window display is at least 80 columns wide and 24 rows long. For more information, see tip(1).
To determine the current dimensions of your tip window, use the stty command. For more information, see the man page, stty(1).
Check your Ethernet connection.
If the system is part of a network, verify that an Ethernet connector or similar network adapter is connected to your system.
Review the planning chapter and other relevant documentation.
  • Review the entire planning chapter or specific sections in Chapter 3, Solaris Installation and Upgrade (Planning).
  • Review the Solaris 10 Release Notes on http://docs.sun.com and vendor release notes to ensure that the software you use is supported in the new Solaris release.
  • Review the Solaris 10 Sun Hardware Platform Guide to ensure that your hardware is supported.
  • Review the documentation that accompanied your system to ensure that your system and devices are supported by the Solaris release.
Checklist for Upgrading
Use the following checklist to gather the information that you need to upgrade the Solaris OS. You do not need to gather all of the information that is requested on the checklist. You only need to collect the information that applies to your system. If you are performing the upgrade over the network, the installation program provides the information for you, based on the current system configuration.
You cannot change basic system identification, such as host name or IP address. The installation program might prompt you for basic system identification, but you must enter the original values. If you use the Solaris installation program to upgrade, the upgrade fails if you attempt to change any of the values.
Table 5–2 Upgrade Checklist
Information for Upgrade
Answer – Defaults are noted with an asterisk (*)
Network connection
Networked/Nonnetworked
DHCP
Yes/No*
IP Address
Subnet
IPv6
Yes/No*
Host Name
# uname -n
Kerberos
Yes/No*
Default Realm:
First KDC:
Name Service
Domain Name
# domainname
NIS+ and NIS
Specify one/Find one*
Server's host name:
    # ypwhich
    # nisping
    hosts.org_dir
DNS
Search Domain:
Search Domain:
Search Domain:
LDAP
Profile Name:
Profile Server:
Default Route
Time Zone
Geographic region*
Offset from GMT
Time zone file
Root Password
Upgrading a system with non-global zones
Starting with the Solaris 10 1/06 release, you can use the Solaris 10 DVD or a DVD-based network installation image to upgrade a system that has non-global zones installed. If you choose to upgrade a system with non-global zones installed, you cannot customize your upgrade.
Note –
In the Solaris 10 1/06 release, you cannot upgrade a system with non-global zones installed with the Solaris 10 Software - 1 CD or the Solaris Live Upgrade installation method.
If your system has more than one root (/) partition or disk, the installation program prompts you to select a root partition to upgrade.
Yes/No
Root (/) to upgrade:
Note –
Locales
Note –
Yes/No
Yes*/No
Yes*/No
Disk space reallocation
Do you want the installation program to automatically re-layout the systems on your disks?
If yes, which file system should be used for auto-layout?
If no, you must provide information for the system configuration.
Yes/No*
Solaris Live Upgrade use
Check the system for the existence of Prestoserve software.
If you begin the upgrade process by shutting down the system with the init 0 command and you're using Prestoserve software, you might lose data. Refer to the Prestoserve documentation for shutdown instructions.
Check for patches needed.
The most recent patch list is provided at http://sunsolve.sun.com.
