This procedure assumes that the system is running the Volume Manager. If you are not using the Volume Manager to manage media, refer to System Administration Guide: Devices and File Systems for detailed information about managing removable media without the Volume Manager.
In the following procedure, the remote system with the DVD-ROM or CD-ROM is identified as remote system. The system that is the client to be installed is identified as client system.
Identify a system that is running the Solaris OS and has a DVD-ROM or CD-ROM drive.
On the remote system with the DVD-ROM or CD-ROM drive, insert the Solaris 10 DVD or the Solaris 10 Software for SPARC Platforms - 1 CD in the drive.
The Volume Manager mounts the disc.
On the remote system, change directories to the DVD or CD where the add_install_client command is located.
For DVD media, type:
remote system# cd /cdrom/cdrom0/s0/Solaris_10/Tools |
For CD media, type:
remote system# cd /cdrom/cdrom0/s0 |
On the remote system, add the system that you want to install as a client.
remote system# ./add_install_client \ client_system_name arch |
For CD media, type:
remote system# ./add_install_client -s remote_system_name: \ /cdrom/cdrom0/s0 client_system_name arch |
The name of the system with the DVD-ROM or CD-ROM drive
The name of the machine you want to install
The platform group of the machine you want to install, for example sun4u. On the system that you want to install, find the platform group by using the uname -m command.
Boot the client system that you want to install.
client system: ok boot net |
The installation begins.
Follow the instructions to type system configuration information if needed.
If you are using DVD media, follow the instructions on the screen to complete the installation. You are finished.
If you are using CD media, the machine reboots and the Solaris installation program begins. After the Welcome panel, the Specify Media panel appears with Network File System selected. Proceed to Step 7.
On the Specify Media panel, click Next.
The Specify Network File System Path panel appears and the text field contains the installation path.
client_system_ip_address:/cdrom/cdrom0/s0
On the remote system where the DVD or CD is mounted, change directories to root.
remote system# cd / |
On the remote system, check for the path to the slice that has been shared.
remote system# share |
On the remote system, unshare the Solaris 10 DVD or Solaris 10 Software for SPARC Platforms - 1 CD by using the path that is found in Step 9. If paths lead to two slices, unshare both slices.
remote system# unshare absolute_path |
Is the absolute path shown in the share command
In this example, slice 0 and slice 1 are unshared.
remote system# unshare /cdrom/cdrom0/s0 remote system# unshare /cdrom/cdrom0/s1 |
On the client system that you are installing, continue the Solaris installation by clicking Next.
If the Solaris installation program prompts you to insert the Solaris 10 Software - 2 CD, repeat Step 9 through Step 11 to unshare the Solaris 10 Software - 1 CD and to export and install the Solaris 10 Software - 2 CD.
If the Solaris installation program prompts you to insert additional Solaris 10 Software CDs, repeat Step 9 through Step 11 to unshare the Solaris 10 Software CDs and to export and install the additional CDs.
If the Solaris installation program prompts you to insert the Solaris 10 Languages CD, repeat Step 9 through Step 11 to unshare the Solaris 10 Software CDs and to export and install the Solaris 10 Languages CD.
When you export the Solaris 10 Languages CD, an installer window appears on the machine where the CD-ROM is mounted. Ignore the installer window while you install the Solaris 10 Languages CD. After you complete the installation of the Solaris 10 Languages CD, close the installer window.
