Solaris 10 Installation Guide: Custom JumpStart and Advanced Installations
system_type Profile Keyword
system_type type_switch
system_type defines the type of system on which the Solaris OS is to be installed.
type_switch represents the option standalone or server, which you use to indicate the type of system on which the Solaris software is to be installed. If you do not specify system_type in a profile, standalone is used by default.
