Use the following procedure only if you store network installation information in the following places:
In the /etc/bootparams file.
In the name service bootparams database. To update the bootparams database, add the entry that is shown in Step 3.
If you use the following procedure, the systems must be of the same type, such as all SPARC systems.
Do not use this procedure under the following conditions:
If you save the JumpStart directory on a diskette
If you specify the location of the profile server when you boot the system
If you have systems of different architectures, you must specify the location of the profile server when you boot the system
If you have the above conditions, use the boot command, or for x86 and the Solaris 10 1/06 release, use the GRUB menu.
You also can store network installation information on a DHCP server.
For SPARC based systems, you use the add_install_client command and the -d option to specify that the custom JumpStart program use the DHCP server. Or you use the boot command with the dhcp option to specify that the custom JumpStart program use the DHCP server. For instructions about using this option, see SPARC: Command Reference for the boot Command.
For x86 based systems, you use the add_install_client command and the -d option to specify that the custom JumpStart program use the DHCP server with PXE.
Starting with the Solaris 10 1/06 release, you can edit the GRUB entry on the GRUB menu and add the dhcp option. For instructions about editing the GRUB entry, see x86: Performing a Custom JumpStart Installation by Editing the GRUB boot Command
On the installation or boot server, log in as superuser.
Use a text editor to open /etc/bootparams.
* install_config=server:jumpstart_dir_path |
A wildcard character that specifies that all systems have access
The host name of the profile server where the JumpStart directory is located
The absolute path of the JumpStart directory
For example, the following entry enables all systems to access the /jumpstart directory on the profile server that is named sherlock:
* install_config=sherlock:/jumpstart |
Use of this procedure might produce the following error message when an installation client is booted:
WARNING: getfile: RPC failed: error 5: (RPC Timed out).
Booting From the Network, Error Messages contains details about this error message.
All systems can now access the profile server.
