Archive Stored on an HTTP or HTTPS Server
If the archive is stored on an HTTP server, use the following syntax for the archive_location keyword.
archive_location http://server_name:port/path/filename optional_keywords
If the archive is stored on an HTTPS server, use the following syntax for the archive_location keyword.
archive_location https://server_name:port/path/filename optional_keywords
server_name
The name of the server where you stored the archive.
port
An optional port. port can be a port number
or the name of a TCP service that has a port number that is determined at runtime.
If you do not specify a port, the Solaris Flash installation utilities
use the default HTTP port number, 80.
path
The location of the archive to be retrieved from the specified server.
If the path contains $HOST, the Solaris Flash installation utilities replace
$HOST with the name of the clone system that you are installing.
filename
The name of the Solaris Flash archive file.
optional_keywords
The optional keywords that you can specify when you retrieve a Solaris Flash archive
from an HTTP server.
Table 11–3 Optional Keywords to Use
With
archive_location HTTP
Keyword
Value Definition
auth basic user_name password
If the archive is located on an HTTP server that is password protected, you
must include the user name and password that you need to access the HTTP server in
the profile file.
Note –
The use of this authentication method in a profile that is intended for
use with custom JumpStart is risky. Unauthorized users might have access to the profile
file that contains the password.
timeout min
The timeout keyword enables you to specify, in minutes, the
maximum length of time that is allowed to pass without receipt of data from the HTTP
server. If a timeout occurs, the connection is closed, reopened, and resumed. If you
specify a timeout value of 0 (zero), the connection is not reopened.
If a timeout reconnection occurs, the Solaris Flash installation
utilities attempt to resume the installation at the last known position in the archive.
If the Solaris Flash installation utilities cannot resume the installation at
the last known position, the retrieval restarts from the beginning of the archive
and the data that was retrieved prior to the timeout is discarded.
If a timeout reconnection occurs while a package is being installed,
the package is retried from the beginning of the package and the data that was retrieved
proxy host:port
The proxy keyword enables you to specify a proxy host and
proxy port. You can use a proxy host to retrieve a Solaris Flash archive from
the other side of a firewall. You must supply a proxy port when you specify the proxy keyword.
Example 11–2 Archive Stored on a HTTP or HTTPS Server
archive_location http://silver/archives/usrarchive.flar timeout 5
Example of the auth basic user_name password keyword:
archive_location http://silver/archives/usrarchive.flar timeout 5 user1 secret
