Solaris 10 Installation Guide: Solaris Flash Archives (Creation and Installation)
SPARC: Supporting Peripheral Devices Not Found on
the Master System
Choosing the drivers to install on the master system has the following dependencies.
The Entire Plus OEM Software Group installs all drivers regardless of the hardware
that is present on the system. Other software groups provide limited support. If you
install another software group and the clone systems have different peripheral devices
than the master system, you need to install the appropriate drivers on the master
system before you create the archive.
How to Get the Support for Peripherals That You Need
You can install support for peripherals on clone systems that are different
from the master system in by installing the Entire Plus OEM Software Group or installing
selected packages.
Type of Installation
Description
Install the Entire Plus OEM Software Group
The Entire Plus OEM Software Group is the largest Software Group available.
This group contains every package that is found in the Solaris OS. The Entire Plus
OEM Software Group installs all drivers regardless of the hardware that is present
on the system. A Solaris Flash archive that is created with the Entire Plus OEM
Software Group works on any clone system that has peripheral devices supported by
the installed release of the Solaris OS.
Installing master systems with the Entire Plus OEM Software Group guarantees
compatibility with other peripheral configurations. However, the Entire Plus OEM Software
Group requires at least 2.9 Gbytes of disk space. The clone systems might not have
the space that is required to install the Entire Plus OEM Software Group.
Install other software groups
If you install the master system with the following software groups, you are
limiting the support for peripherals. The master system supports only the peripheral
devices that are attached to the master system at the time of installation.
Installing these software groups could result in your clone systems failing
to have all the drivers needed. For example, if you install the Entire Software Group
on a master system that has a GX CG6 frame buffer, only the GX CG6 frame buffer driver
is installed. This situation is not a problem if all the clone systems that you want
to install have the GX CG6 frame buffer or no frame buffer.
Install selected packages
When you install the master system, you can install only the packages that you
need for the master system and the clone systems. By selecting specific packages,
you can install only support for the peripherals that you know exist on the master
system or clone systems.
