Solaris Dynamic Tracing Guide
ustack()
void ustack(int nframes, int strsize)
void ustack(int nframes)
void ustack(void)
The ustack() action records a user stack trace to the directed buffer. The user stack will be nframes in depth. If nframes is not provided, the number of stack frames recorded is the number specified by the ustackframes option. While ustack() is able to determine the address of the calling frames when the probe fires, the stack frames will not be translated into symbols until the ustack() action is processed at user-level by the DTrace consumer. If strsize is specified and non-zero, ustack() will allocate the specified amount of string space, and use it to perform address-to-symbol translation directly from the kernel. This direct user symbol translation is currently available only for Java virtual machines, version 1.5 and higher. Java address-to-symbol translation annotates user stacks that contain Java frames with the Java class and method name. If such frames cannot be translated, the frames will appear only as hexadecimal addresses.
The following example traces a stack with no string space, and therefore no Java address-to-symbol translation:
# dtrace -n syscall::write:entry'/pid == $target/{ustack(50, 0);
    exit(0)}' -c "java -version"
dtrace: description 'syscall::write:entry' matched 1 probe
java version "1.5.0-beta3"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0-beta3-b58)
Java HotSpot(TM) Client VM (build 1.5.0-beta3-b58, mixed mode)
dtrace: pid 5312 has exited
CPU     ID                    FUNCTION:NAME
  0     35                      write:entry
              libc.so.1`_write+0x15
              libjvm.so`__1cDhpiFwrite6FipkvI_I_+0xa8
              libjvm.so`JVM_Write+0x2f
              d0c5c946
              libjava.so`Java_java_io_FileOutputStream_writeBytes+0x2c
              cb007fcd
              cb002a7b
              cb002a7b
              cb002a7b
              cb002a7b
              cb002a7b
              cb002a7b
              cb002a7b
              cb002a7b
              cb002a7b
              cb002a7b
              cb002a7b
              cb002a7b
              cb002a7b
              cb000152
              libjvm.so`__1cJJavaCallsLcall_helper6FpnJJavaValue_
                          pnMmethodHandle_pnRJavaCallArguments_
                          pnGThread__v_+0x187
              libjvm.so`__1cCosUos_exception_wrapper6FpFpnJJavaValue_
                          pnGThread__v2468_v_+0x14
              libjvm.so`__1cJJavaCallsEcall6FpnJJavaValue_nMmethodHandle_
                          pnRJavaCallArguments_pnGThread __v_+0x28
              libjvm.so`__1cRjni_invoke_static6FpnHJNIEnv__pnJJavaValue_
                          pnI_jobject_nLJNICallType_pnK_jmethodID_pnSJNI_
                          ArgumentPusher_pnGThread__v_+0x180
              libjvm.so`jni_CallStaticVoidMethod+0x10f
              java`main+0x53d
Notice that the C and C++ stack frames from the Java virtual machine are presented symbolically using C++ “mangled” symbol names, and the Java stack frames are presented only as hexadecimal addresses. The following example shows a call to ustack() with a non-zero string space:
# dtrace -n syscall::write:entry'/pid == $target/{ustack(50, 500); exit(0)}'
      -c "java -version"
dtrace: pid 5308 has exited
  0     35                      write:entry
              d0c5c946
              java/io/FileOutputStream.writeBytes
              java/io/BufferedOutputStream.flushBuffer
              java/io/PrintStream.write
              sun/nio/cs/StreamEncoder$CharsetSE.writeBytes
              sun/nio/cs/StreamEncoder$CharsetSE.implFlushBuffer
              sun/nio/cs/StreamEncoder.flushBuffer
              java/io/OutputStreamWriter.flushBuffer
              java/io/PrintStream.print
              java/io/PrintStream.println
              sun/misc/Version.print
              StubRoutines (1)
                          pnMmethodHandle_pnRJavaCallArguments_pnGThread
                          __v_+0x187
                          __v2468_v_+0x14
                          _pnRJavaCallArguments_pnGThread__v_+0x28
              libjvm.so`__1cRjni_invoke_static6FpnHJNIEnv__pnJJavaValue_pnI
                          _ArgumentPusher_pnGThread__v_+0x180
              java`main+0x53d
              8051b9a
The above example output demonstrates symbolic stack frame information for Java stack frames. There are still some hexadecimal frames in this output because some functions are static and do not have entries in the application symbol table. Translation is not possible for these frames.
The ustack() symbol translation for non-Java frames occurs after the stack data is recorded. Therefore, the corresponding user process might exit before symbol translation can be performed, making stack frame translation impossible. If the user process exits before symbol translation is performed, dtrace will emit a warning message, followed by the hexadecimal stack frames, as shown in the following example:
  dtrace: failed to grab process 100941: no such process
                c7b834d4
                c7bca85d
                c7bca1a4
                c7bd4374
                c7bc2628
                8047efc
Techniques for mitigating this problem are described in Chapter 33, User Process Tracing.
Finally, because the postmortem DTrace debugger commands cannot perform the frame translation, using ustack() with a ring buffer policy always results in raw ustack() data.
The following D program shows an example of ustack() that leaves strsize unspecified:
syscall::brk:entry
/execname == $$1/
	@[ustack(40)] = count();
To run this example for the Netscape web browser, .netscape.bin in default Solaris installations, use the following command:
# dtrace -s brk.d .netscape.bin
dtrace: description 'syscall::brk:entry' matched 1 probe
^C
                libc.so.1`_brk_unlocked+0xc
                88143f6
                88146cd
                .netscape.bin`unlocked_malloc+0x3e
                .netscape.bin`unlocked_calloc+0x22
                .netscape.bin`calloc+0x26
                .netscape.bin`_IMGCB_NewPixmap+0x149
                .netscape.bin`il_size+0x2f7
                .netscape.bin`il_jpeg_write+0xde
                8440c19
                .netscape.bin`il_first_write+0x16b
                8394670
                83928e5
                .netscape.bin`NET_ProcessHTTP+0xa6
                .netscape.bin`NET_ProcessNet+0x49a
                827b323
                libXt.so.4`XtAppProcessEvent+0x38f
                .netscape.bin`fe_EventLoop+0x190
                .netscape.bin`main+0x1875
                   1
                libc.so.1`sbrk+0x29
                88143df
                88146cd
                8440c19
                8394670
                83928e5
                827b323
                  1
