Solaris Dynamic Tracing Guide
Probe Arguments
The arguments for each SDT probe are the arguments specified in the corresponding DTRACE_PROBEn macro reference. The number of arguments depends on which macro was used to create the probe: DTRACE_PROBE1 specifies one argument, DTRACE_PROBE2 specifies two arguments, and so on. When declaring your SDT probes, you can minimize their disabled probe effect by not dereferencing pointers and not loading from global variables in the probe arguments. Both pointer dereferencing and global variable loading may be done safely in D actions that enable probes, so DTrace users can request these actions only when they are needed.
