Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_GraphicsDrawPoint_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 c);
mlib_status mlib_GraphicsDrawPoint_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsDrawPoint_X_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 c, mlib_s32 c2);
mlib_status mlib_GraphicsDrawPoint_X_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsDrawPoint_B_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 c, mlib_s32 a);
mlib_status mlib_GraphicsDrawPoint_B_32(mlib_image *buffer, mlib_s16 x,
Each of the mlib_GraphicsDrawPoint_*() functions draws a point at (x,y) in color c.
Each of the mlib_GraphicsDrawPoint_X_*() functions draws a point at (x,y) in Xor mode as follows:
data[x,y] ^= c ^ c2
Each of the mlib_GraphicsDrawPoint_B_*() functions draws a point at (x,y) with alpha blending as follows:
data[x,y] = (data[x,y] * (255 - a) + c * a) / 255
Each of the functions takes some of the following arguments:
Pointer to the image into which the function is drawing.
X coordinate of the point.
Y coordinate of the point.
Color used in the drawing.
Alternation color.
Alpha value for blending. 0 ≤ a ≤ 255.
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
| ATTRIBUTE TYPE | ATTRIBUTE VALUE |
| Interface Stability | Committed |
| MT-Level | MT-Safe |
