Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_GraphicsDrawTriangleStripSet_8(mlib_image *buffer,
     const mlib_s16 *x, const mlib_s16 *y, mlib_s32 npoints, mlib_s32 c);
mlib_status mlib_GraphicsDrawTriangleStripSet_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawTriangleStripSet_X_8(mlib_image *buffer,
     const mlib_s16 *x, const mlib_s16 *y, mlib_s32 npoints, mlib_s32 c,
     mlib_s32 c2);
mlib_status mlib_GraphicsDrawTriangleStripSet_X_32(mlib_image *buffer,
     mlib_s32 c2);
mlib_status mlib_GraphicsDrawTriangleStripSet_A_8(mlib_image *buffer,
mlib_status mlib_GraphicsDrawTriangleStripSet_A_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawTriangleStripSet_B_8(mlib_image *buffer,
     mlib_s32 a);
mlib_status mlib_GraphicsDrawTriangleStripSet_B_32(mlib_image *buffer,
     mlib_s32 a);
mlib_status mlib_GraphicsDrawTriangleStripSet_G_8(mlib_image *buffer,
     mlib_s32 npoints, const mlib_s32 *c);
mlib_status mlib_GraphicsDrawTriangleStripSet_G_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawTriangleStripSet_Z_8(mlib_image *buffer,
     mlib_image *zbuffer, const mlib_s16 *x, const mlib_s16 *y,
     const mlib_s16 *z, mlib_s32 npoints, mlib_s32 c);
mlib_status mlib_GraphicsDrawTriangleStripSet_Z_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawTriangleStripSet_AB_8(mlib_image *buffer,
     mlib_s32 a);
mlib_status mlib_GraphicsDrawTriangleStripSet_AB_32(mlib_image *buffer,
     mlib_s32 a);
mlib_status mlib_GraphicsDrawTriangleStripSet_ABG_8(mlib_image *buffer,
     const mlib_s32 *c, mlib_s32 a);
mlib_status mlib_GraphicsDrawTriangleStripSet_ABG_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawTriangleStripSet_ABGZ_8(mlib_image *buffer,
     const mlib_s16 *z, mlib_s32 npoints, const mlib_s32 *c, mlib_s32 a);
mlib_status mlib_GraphicsDrawTriangleStripSet_ABGZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawTriangleStripSet_ABZ_8(mlib_image *buffer,
     const mlib_s16 *z, mlib_s32 npoints, mlib_s32 c, mlib_s32 a);
mlib_status mlib_GraphicsDrawTriangleStripSet_ABZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawTriangleStripSet_AG_8(mlib_image *buffer,
     const mlib_s32 *c);
mlib_status mlib_GraphicsDrawTriangleStripSet_AG_32(mlib_image *buffer,
     const mlib_s32 *c);
mlib_status mlib_GraphicsDrawTriangleStripSet_AGZ_8(mlib_image *buffer,
     const mlib_s16 *z, mlib_s32 npoints, const mlib_s32 *c);
mlib_status mlib_GraphicsDrawTriangleStripSet_AGZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawTriangleStripSet_AZ_8(mlib_image *buffer,
mlib_status mlib_GraphicsDrawTriangleStripSet_AZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawTriangleStripSet_BG_8(mlib_image *buffer,
mlib_status mlib_GraphicsDrawTriangleStripSet_BG_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawTriangleStripSet_BGZ_8(mlib_image *buffer,
mlib_status mlib_GraphicsDrawTriangleStripSet_BGZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawTriangleStripSet_BZ_8(mlib_image *buffer,
mlib_status mlib_GraphicsDrawTriangleStripSet_BZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsDrawTriangleStripSet_GZ_8(mlib_image *buffer,
mlib_status mlib_GraphicsDrawTriangleStripSet_GZ_32(mlib_image *buffer,
Each of the mlib_GraphicsDrawTriangleStripSet_*() functions draws a set of triangles with vertices at {(x1,y1), (x2,y2), (x3,y3)}, {(x2,y2), (x3,y3), (x4,y4)}, ..., and {(xn-2,yn-2), (xn-1,yn-1), (xn,yn)}.
Each of the mlib_GraphicsDrawTriangleStripSet_X_*() functions draws a set of triangles in Xor mode as follows:
data[x,y] ^= c ^ c2
Each of the mlib_GraphicsDrawTriangleStripSet_A_*() functions draws a set of triangles with antialiasing.
Each of the mlib_GraphicsDrawTriangleStripSet_B_*() functions draws a set of triangles with alpha blending as follows:
data[x,y] = (data[x,y] * (255 - a) + c * a) / 255
Each of the mlib_GraphicsDrawTriangleStripSet_G_*() functions draws a set of triangles with Gouraud shading.
Each of the mlib_GraphicsDrawTriangleStripSet_Z_*() functions draws a set of triangles with Z buffering.
Each of the other functions draws a set of triangles with a combination of two or more features like antialiasing (A), alpha blending (B), Gouraud shading (G), and Z buffering (Z).
Each of the functions takes some of the following arguments:
Pointer to the image into which the function is drawing.
Pointer to the image that holds the Z buffer.
Pointer to array of X coordinates of the points.
Pointer to array of Y coordinates of the points.
Pointer to array of Z coordinates of the points.
Number of points in the arrays.
Color used in the drawing, or pointer to array of colors of the points in the case of Gouraud shading.
Alternation color.
Alpha value for blending. 0 ≤ a ≤ 255.
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
| ATTRIBUTE TYPE | ATTRIBUTE VALUE |
| Interface Stability | Committed |
| MT-Level | MT-Safe |
mlib_GraphicsDrawTriangle(3MLIB), mlib_GraphicsDrawTriangleSet(3MLIB), mlib_GraphicsDrawTriangleFanSet(3MLIB), attributes(5)
