Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ] #include <mlib.h> mlib_status mlib_ImageMaximum_Fp(mlib_d64 *max, const mlib_image *img);
The mlib_ImageMaximum_Fp() function determines the maximum value for each channel in a floating-point image.
It uses the following equation:
max[i] = MAX{ img[x][y][i]; 0 ≤ x < w, 0 ≤ y < h }
The function takes the following arguments:
Pointer to maximum vector, where length is the number of channels in the image. max[i] contains the maximum of channel i.
Pointer to a source image.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
