Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_ImageScalarBlend_Inp(mlib_image *src1dst,
const mlib_image *src2, const mlib_s32 *alpha);
The mlib_ImageScalarBlend_Inp() function blends the first and second source images by adding each of their scaled pixels in place. The first source image is scaled by the scalar a, and the second source image is inverse scaled by (1 - a).
It uses the following equation:
src1dst[x][y][i] = a[i]*src1dst[x][y][i] +
(1 - a[i])*src2[x][y][i]
The function takes the following arguments:
Pointer to first source and destination image.
Pointer to second source image.
Scalar blending factor. The a value equals (alpha * 2**(-31)). alpha[i] contains the blending factor for channel i.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
mlib_ImageScalarBlend(3MLIB), mlib_ImageScalarBlend_Fp(3MLIB), mlib_ImageScalarBlend_Fp_Inp(3MLIB), attributes(5)
