Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ] #include <mlib.h> void *mlib_realloc(void *ptr, size_t size);
The mlib_realloc() function changes the size of the block pointed to by ptr to size bytes and returns a pointer to the (possibly moved) block.
This function is a wrapper of the standard C function realloc().
The function takes the following arguments:
New size of the block in bytes.
Pointer to a block.
The function returns a pointer to the reallocated block if successful. Otherwise it returns a null pointer.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
