Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_SignalADPCM5Bits2Linear(mlib_s16 *pcm,
     const mlib_u8 *adpcm, void *state, mlib_s32 n);
The mlib_SignalADPCM5Bits2Linear() function performs adaptive differential pulse code modulation (ADPCM) in compliance with the ITU (former CCITT) G.721, G.723, and G.726 specifications. It converts data fromG.723 or G.726 40kbps 5-bit ADPCM to 16-bit linear PCM format.
The function takes the following arguments:
Linear PCM sample array.
ADPCM code array.
Internal structure of the codec.
Number of samples in the source array.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
 ATTRIBUTE TYPE  |
 ATTRIBUTE VALUE  |
 Interface Stability  |
 Committed  |
 MT-Level  |
 MT-Safe  |
mlib_SignalADPCM2Bits2Linear(3MLIB), mlib_SignalADPCM3Bits2Linear(3MLIB), mlib_SignalADPCM4Bits2Linear(3MLIB), mlib_SignalADPCMFree(3MLIB), mlib_SignalADPCMInit(3MLIB), mlib_SignalLinear2ADPCM2Bits(3MLIB), mlib_SignalLinear2ADPCM3Bits(3MLIB), mlib_SignalLinear2ADPCM4Bits(3MLIB), mlib_SignalLinear2ADPCM5Bits(3MLIB), attributes(5)
