Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_SignalDownSample_S16_S16(mlib_s16 *dst,
const mlib_s16 *src, mlib_s32 factor, mlib_s32 phase,
mlib_s32 n);
mlib_status mlib_SignalDownSample_S16S_S16S(mlib_s16 *dst,
mlib_s32 n);
mlib_status mlib_SignalDownSample_F32_F32(mlib_f32 *dst,
const mlib_f32 *src, mlib_s32 factor, mlib_s32 phase,
mlib_s32 n);
mlib_status mlib_SignalDownSample_F32S_F32S(mlib_f32 *dst,
mlib_s32 n);
Each of these functions performs downsampling.
For monaural signals, the following equation is used:
dst[i] = src[i*factor + phase]
where i = 0, 1, ..., (n - 1 - phase)/factor.
For stereo signals, the following equation is used:
dst[2*i] = src[2*(i*factor + phase)] dst[2*i + 1] = src[2*(i*factor + phase) + 1]
Each of the functions takes the following arguments:
Output signal array.
Input signal array.
Factor by which to downsample. factor ≥ 1.
Parameter that determines relative position of an output value, within the input signal. 0 ≤ phase < factor.
Number of samples in the input signal array.
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
