Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VideoColorABGR2JFIFYCC444(mlib_u8 *y, mlib_u8 *cb,
mlib_u8 *cr, const mlib_u8 *abgr, mlib_s32 n);
The mlib_VideoColorABGR2JFIFYCC444() function performs color space conversion from and ABGR to YCbCr when used in the JPEG File Interchange Format (JFIF).
The following equation is used:
Y = 0.29900 * R + 0.58700 * G + 0.11400 * B Cb = -0.16874 * R - 0.33126 * G + 0.50000 * B + 128 Cr = 0.50000 * R - 0.41869 * G - 0.08131 * B + 128
The function takes the following arguments:
Pointer to destination Y component row. y must be 8-byte aligned.
Pointer to destination Cb component row. cb must be 8-byte aligned.
Pointer to destination Cr component row. cr must be 8-byte aligned.
Pointer to source ABGR multi-component row. abgr must be 8-byte aligned.
Length of Y component row. The length of Cb and Cr component rows must be n. The length of the ABGR multi-component row must be 4*n.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
mlib_VideoColorARGB2JFIFYCC444(3MLIB), mlib_VideoColorRGB2JFIFYCC444(3MLIB), mlib_VideoColorRGB2JFIFYCC444_S16(3MLIB), attributes(5)
