Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VideoColorJFIFYCC2RGB444_S16(mlib_s16 *rgb,
const mlib_s16 *y, const mlib_s16 *cb,
const mlib_s16 *cr, mlib_s32 n);
The mlib_VideoColorJFIFYCC2RGB444_S16() function performs color space conversion from YCbCr to RGB when used in the JPEG File Interchange Format (JFIF).
Both the input YCbCr components and the output RGB components are supposed to be in the range of [0, 4095].
The following equation is used:
R = Y + 1.40200 * (Cr - 2048) G = Y - 0.34414 * (Cb - 2048) - 0.71414 * (Cr - 2048) B = Y + 1.77200 * (Cb - 2048)
The function takes the following arguments:
Pointer to destination RGB multi-component row. rgb must be 8-byte aligned.
Pointer to source Y component row. y must be 8-byte aligned.
Pointer to source Cb component row. cb must be 8-byte aligned.
Pointer to source Cr component row. cr must be 8-byte aligned.
Length of Y component row. The length of Cb and Cr component rows must be n. The length of the RGB multi-component row must be 3*n.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
mlib_VideoColorJFIFYCC2ABGR444(3MLIB), mlib_VideoColorJFIFYCC2ARGB444(3MLIB), mlib_VideoColorJFIFYCC2RGB444(3MLIB), attributes(5)
