Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VideoColorSplit3(mlib_u8 *color1, mlib_u8 *color2,
mlib_u8 *color3, const mlib_u8 *colors, mlib_s32 n);
The mlib_VideoColorSplit3() function performs color channel split.
The elements of the colors array are selected in consecutive groups of three. As each group is processed, the first element is stored in the color1 array; the second element, in the color2 array; and the third element, in the color3 array. This process is repeated untill the end of the colors array is reached.
The function takes the following arguments:
Pointer to first color component row. color1 must be 8-byte aligned.
Pointer to second color component row. color2 must be 8-byte aligned.
Pointer to colors multi-component row. colors must be 8-byte aligned.
Length of color1, color2, and color3 arrays. Length of colors must be 3*n.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
mlib_VideoColorMerge2(3MLIB), mlib_VideoColorMerge2_S16(3MLIB), mlib_VideoColorMerge3(3MLIB), mlib_VideoColorMerge3_S16(3MLIB), mlib_VideoColorMerge4(3MLIB), mlib_VideoColorMerge4_S16(3MLIB), mlib_VideoColorSplit2(3MLIB), mlib_VideoColorSplit2_S16(3MLIB), mlib_VideoColorSplit3_S16(3MLIB), mlib_VideoColorSplit4(3MLIB), mlib_VideoColorSplit4_S16(3MLIB), attributes(5)
