Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ] #include <mlib.h> mlib_status mlib_VideoDCT8x8Quantize_S16_S16_B12_NA( mlib_s16 coeffs[64], const mlib_s16 block[64], const mlib_d64 dqtable[64]);
The mlib_VideoDCT8x8Quantize_S16_S16_B12_NA() function computes the forward DCT and then quantizes the DCT coefficients. It's a combination of mlib_VideoDCT8x8_S16_S16_B12_NA() and mlib_VideoQuantize_S16() for better performance. The source to the DCT routine can occupy up to 12 bits for each of its elements, i.e., should be within the range of [-2048, 2047].
This function requires no special address alignment.
This function can be used in JPEG with 12-bit precision, or in MPEG for the inter mode.
The function takes the following arguments:
Pointer to the quantized DCT coefficients.
Pointer to an 8x8 block.
Pointer to the quantization table generated by mlib_VideoQuantizeInit_S16().
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
mlib_VideoDCT8x8Quantize_S16_S16_B12(3MLIB), mlib_VideoDCT8x8Quantize_S16_U8(3MLIB), mlib_VideoDCT8x8Quantize_S16_U8_NA(3MLIB), mlib_VideoQuantizeInit_S16(3MLIB), attributes(5)
