Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VideoIDCT8x8_U8_S16_DC(mlib_u8 *block,
     const mlib_s16 *coeffs, mlib_s32 stride);
The mlib_VideoIDCT8x8_U8_S16_DC() function can be used only when F(0,0) is nonzero. It computes the inverse DCT (called IDCT) for the destination IDCT block of data type mlib_u8 and source DCT coefficients of data type mlib_s16. This function is not guaranteed to be IEEE-1180-compliant. The output of the IDCT routine is the difference between the current block and the reference block. The difference pixel can occupy nine bits and is represented as a 16-bit datum. The output must be added to the motion-compensated reference block in order to reconstruct the current block.
The function takes the following arguments:
Pointer to the current block. block must be 8-byte aligned.
Pointer to the source DCT coefficients. coeffs must be 8-byte aligned.
Stride, in bytes, between adjacent rows in a block. stride must be a multiple of eight..
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
 ATTRIBUTE TYPE  |
 ATTRIBUTE VALUE  |
 Interface Stability  |
 Committed  |
 MT-Level  |
 MT-Safe  |
mlib_VideoIDCT_IEEE_S16_S16(3MLIB), mlib_VideoIDCT8x8_S16_S16(3MLIB), mlib_VideoIDCT8x8_S16_S16_DC(3MLIB), mlib_VideoIDCT8x8_S16_S16_NA(3MLIB), mlib_VideoIDCT8x8_S16_S16_Q1(3MLIB), mlib_VideoIDCT8x8_U8_S16(3MLIB), mlib_VideoIDCT8x8_U8_S16_NA(3MLIB), mlib_VideoIDCT8x8_U8_S16_Q1(3MLIB), attributes(5)
