Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VideoUpSample422_Nearest_S16(mlib_s16 *dst,
const mlib_s16 *src, mlib_s32 n);
The mlib_VideoUpSample422_Nearest_S16() function performs up sampling rate conversion used in JPEG File Interchange Format (JFIF).
The function takes the following arguments:
Pointer to destination row. dst must be 8-byte aligned.
Pointer to source row. src must be 8-byte aligned.
Length of source rows. n must be greater than 1.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
mlib_VideoDownSample420(3MLIB), mlib_VideoDownSample420_S16(3MLIB), mlib_VideoDownSample422(3MLIB), mlib_VideoDownSample422_S16(3MLIB), mlib_VideoUpSample420(3MLIB), mlib_VideoUpSample420_Nearest(3MLIB), mlib_VideoUpSample420_Nearest_S16(3MLIB), mlib_VideoUpSample420_S16(3MLIB), mlib_VideoUpSample422(3MLIB), mlib_VideoUpSample422_S16(3MLIB), mlib_VideoUpSample422_Nearest(3MLIB), attributes(5)
