RMI has been enhanced in the following areas:
Dynamic Generation of Stub Classes - This release adds support for the dynamic generation of stub classes at runtime, obviating the need to use the Java Remote Method Invocation (Java RMI) stub compiler, rmic, to pregenerate stub classes for remote objects. Note that rmic must still be used to pregenerate stub classes for remote objects that need to support clients running on earlier versions.
Standard SSL/TLS Socket Factory Classes - This release adds standard Java RMI socket factory classes, javax.rmi.ssl.SslRMIClientSocketFactory and javax.rmi.ssl.SslRMIServer SocketFactory, which communicate over the Secure Sockets Layer (SSL) or Transport Layer Security (TLS) protocols using the Java Secure Socket Extension (JSSE).
Launching rmid or a Java RMI Server from inetd/xinetd - A new feature, provided by the System.inheritedChannel method, allows an application to obtain a channel (java.nio.channels.SocketChannel or java.nio.channels.ServerSocketChannel, for example) inherited from the process that launched the virtual machine (VM). Such an inherited channel can be used to either service a single incoming connection (as with SocketChannel) or accept multiple incoming connections (as with ServerSocketChannel). Therefore, Java networking applications launched by inetd (Solaris(tm) Operating System) or xinetd (Linux) can now obtain the SocketChannel or ServerSocketChannel inherited from inetd/xinetd.
Refer to the documentation at http://java.sun.com/j2se/1.5.0/docs/guide/rmi/index.html.
