次のコードリストは、「SASL の例」に記載されているサーバーの例を対象としています。
このソースコード例は、Sun ダウンロードセンターからダウンロードすることも可能です。http://www.sun.com/download/products.xml?id=41912db5 を参照してください。
#pragma ident	"@(#)server.c	1.3	03/04/07 SMI"
/* $Id: server.c,v 1.4 2002/10/07 05:04:05 rjs3 Exp $ */
 * Copyright (c) 2001 Carnegie Mellon University.  All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * 1. Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 * 2. Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in
 *    the documentation and/or other materials provided with the
 *    distribution.
 * 3. The name "Carnegie Mellon University" must not be used to
 *    endorse or promote products derived from this software without
 *    prior written permission. For permission or any other legal
 *    details, please contact
 *      Office of Technology Transfer
 *      Carnegie Mellon University
 *      5000 Forbes Avenue
 *      Pittsburgh, PA  15213-3890
 *      (412) 268-4387, fax: (412) 268-7395
 *      tech-transfer@andrew.cmu.edu
 * 4. Redistributions of any form whatsoever must retain the following
 *    acknowledgment:
 *    "This product includes software developed by Computing Services
 *     at Carnegie Mellon University (http://www.cmu.edu/computing/)."
 * CARNEGIE MELLON UNIVERSITY DISCLAIMS ALL WARRANTIES WITH REGARD TO
 * THIS SOFTWARE, INCLUDING ALL IMPLIED WARRANTIES OF MERCHANTABILITY
 * AND FITNESS, IN NO EVENT SHALL CARNEGIE MELLON UNIVERSITY BE LIABLE
 * FOR ANY SPECIAL, INDIRECT OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
 * WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN
 * AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING
 * OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
#include <config.h>
#include <stdio.h>
#include <stdlib.h>
#include <stdarg.h>
#include <ctype.h>
#include <errno.h>
#include <string.h>
#ifdef HAVE_UNISTD_H
#include <unistd.h>
#endif
#include <sys/socket.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#include <netdb.h>
#ifdef _SUN_SDK_
#include <sysexits.h>
#endif /* _SUN_SDK_ */
#include <sasl.h>
#include "common.h"
#if !defined(IPV6_BINDV6ONLY) && defined(IN6P_IPV6_V6ONLY)
#define IPV6_BINDV6ONLY IN6P_BINDV6ONLY
#endif
#if !defined(IPV6_V6ONLY) && defined(IPV6_BINDV6ONLY)
#define	IPV6_V6ONLY	IPV6_BINDV6ONLY
#endif
#ifndef IPV6_BINDV6ONLY
#undef      IPV6_V6ONLY
#endif
static int getpath(void * context __attribute__((unused)),
	const char **path)
    *path = getenv("SASL_PATH");
    if (*path == NULL)
	*path = PLUGINDIR;
    return SASL_OK;
/* callbacks we support */
static sasl_callback_t callbacks[] = {
    SASL_CB_GETPATH, &getpath, NULL
    SASL_CB_LIST_END, NULL, NULL
/* create a socket listening on port 'port' */
/* if af is PF_UNSPEC more than one socket might be returned */
/* the returned list is dynamically allocated, so caller needs to free it */
int *listensock(const char *port, const int af)
    struct addrinfo hints, *ai, *r;
    int err, maxs, *sock, *socks;
    const int on = 1;
    memset(&hints, 0, sizeof(hints));
    hints.ai_flags = AI_PASSIVE;
    hints.ai_family = af;
    hints.ai_socktype = SOCK_STREAM;
    err = getaddrinfo(NULL, port, &hints, &ai);
    if (err) {
	fprintf(stderr, "%s\n", gai_strerror(err));
	exit(EX_USAGE);
    /* Count max number of sockets we can open */
    for (maxs = 0, r = ai; r; r = r->ai_next, maxs++)
    socks = malloc((maxs + 1) * sizeof(int));
    if (!socks) {
	fprintf(stderr, "couldn't allocate memory for sockets\n");
	freeaddrinfo(ai);
	exit(EX_OSERR);
    socks[0] = 0;	/* num of sockets counter at start of array */
    sock = socks + 1;
    for (r = ai; r; r = r->ai_next) {
	fprintf(stderr, "trying %d, %d, %d\n",r->ai_family, r->ai_socktype,
     r->ai_protocol);
	*sock = socket(r->ai_family, r->ai_socktype, r->ai_protocol);
	if (*sock < 0) {
	    perror("socket");
	    continue;
	if (setsockopt(*sock, SOL_SOCKET, SO_REUSEADDR,
		       (void *) &on, sizeof(on)) < 0) {
	    perror("setsockopt(SO_REUSEADDR)");
	    close(*sock);
	    continue;
#if defined(IPV6_V6ONLY) && !(defined(__FreeBSD__) && __FreeBSD__ < 3)
	if (r->ai_family == AF_INET6) {
	    if (setsockopt(*sock, IPPROTO_IPV6, IPV6_BINDV6ONLY,
		perror("setsockopt (IPV6_BINDV6ONLY)");
		close(*sock);
		continue;
#endif
	if (bind(*sock, r->ai_addr, r->ai_addrlen) < 0) {
	    perror("bind");
	    close(*sock);
	    continue;
 	if (listen(*sock, 5) < 0) {
 	    perror("listen");
 	    close(*sock);
 	    continue;
 	socks[0]++;
 	sock++;
    freeaddrinfo(ai);
    if (socks[0] == 0) {
 	fprintf(stderr, "Couldn't bind to any socket\n");
 	free(socks);
	exit(EX_OSERR);
    return socks;
#ifdef _SUN_SDK_
void usage(const char *s)
#else
void usage(void)
#ifdef _SUN_SDK_
    fprintf(stderr, "usage: %s [-p port] [-s service] [-m mech]\n", s);
#else
    fprintf(stderr, "usage: server [-p port] [-s service] [-m mech]\n");
    exit(EX_USAGE);
/* Globals are used here, but local variables are preferred */
char *mech;
/* do the sasl negotiation; return -1 if it fails */
int mysasl_negotiate(FILE *in, FILE *out, sasl_conn_t *conn)
    char buf[8192];
    char chosenmech[128];
    const char *data;
#ifdef _SUN_SDK_
    unsigned len;
#else
    int len;
    int r = SASL_FAIL;
    const char *userid;
    /* generate the capability list */
    if (mech) {
	dprintf(2, "forcing use of mechanism %s\n", mech);
	data = strdup(mech);
    } else {
	int count;
	dprintf(1, "generating client mechanism list... ");
	r = sasl_listmech(conn, NULL, NULL, " ", NULL,
			  &data, &len, &count);
	if (r != SASL_OK) saslfail(r, "generating mechanism list");
	dprintf(1, "%d mechanisms\n", count);
    /* send capability list to client */
    send_string(out, data, len);
    dprintf(1, "waiting for client mechanism...\n");
    len = recv_string(in, chosenmech, sizeof chosenmech);
    if (len <= 0) {
	printf("client didn't choose mechanism\n");
	fputc('N', out); /* send NO to client */
	fflush(out);
	return -1;
    if (mech && strcasecmp(mech, chosenmech)) {
	printf("client didn't choose mandatory mechanism\n");
	fflush(out);
	return -1;
    len = recv_string(in, buf, sizeof(buf));
    if(len != 1) {
	saslerr(r, "didn't receive first-send parameter correctly");
	fputc('N', out);
	fflush(out);
	return -1;
    if(buf[0] == 'Y') {
        /* receive initial response (if any) */
        /* start libsasl negotiation */
        r = sasl_server_start(conn, chosenmech, buf, len,
			      &data, &len);
    } else {
	r = sasl_server_start(conn, chosenmech, NULL, 0,
			      &data, &len);
    if (r != SASL_OK && r != SASL_CONTINUE) {
	saslerr(r, "starting SASL negotiation");
	fflush(out);
	return -1;
    while (r == SASL_CONTINUE) {
	if (data) {
	    dprintf(2, "sending response length %d...\n", len);
	    fputc('C', out); /* send CONTINUE to client */
	} else {
	    dprintf(2, "sending null response...\n");
	    send_string(out, "", 0);
	dprintf(1, "waiting for client reply...\n");
	len = recv_string(in, buf, sizeof buf);
	if (len < 0) {
	    printf("client disconnected\n");
	    return -1;
	r = sasl_server_step(conn, buf, len, &data, &len);
	    saslerr(r, "performing SASL negotiation");
	    fflush(out);
	    return -1;
    if (r != SASL_OK) {
	saslerr(r, "incorrect authentication");
	fflush(out);
	return -1;
    fputc('O', out); /* send OK to client */
    fflush(out);
    dprintf(1, "negotiation complete\n");
    r = sasl_getprop(conn, SASL_USERNAME, (const void **) &userid);
    printf("successful authentication '%s'\n", userid);
    return 0;
int main(int argc, char *argv[])
    int c;
    char *port = "12345";
    char *service = "rcmd";
    int *l, maxfd=0;
    int r, i;
    sasl_conn_t *conn;
    while ((c = getopt(argc, argv, "p:s:m:")) != EOF) {
	switch(c) {
	case 'p':
	    port = optarg;
	    break;
	case 's':
	    service = optarg;
	    break;
	case 'm':
	    mech = optarg;
	    break;
	default:
#ifdef _SUN_SDK_
	    usage(argv[0]);
#else
	    usage();
	    break;
    /* initialize the sasl library */
    r = sasl_server_init(callbacks, "sample");
    if (r != SASL_OK) saslfail(r, "initializing libsasl");
    /* get a listening socket */
    if ((l = listensock(port, PF_UNSPEC)) == NULL) {
	saslfail(SASL_FAIL, "allocating listensock");
    for (i = 1; i <= l[0]; i++) {
       if (l[i] > maxfd)
           maxfd = l[i];
    for (;;) {
	char localaddr[NI_MAXHOST | NI_MAXSERV],
	     remoteaddr[NI_MAXHOST | NI_MAXSERV];
	char myhostname[1024+1];
	char hbuf[NI_MAXHOST], pbuf[NI_MAXSERV];
	struct sockaddr_storage local_ip, remote_ip;
	int salen;
	int nfds, fd = -1;
	FILE *in, *out;
	fd_set readfds;
	FD_ZERO(&readfds);
	    FD_SET(l[i], &readfds);
	nfds = select(maxfd + 1, &readfds, 0, 0, 0);
	if (nfds <= 0) {
	    if (nfds < 0 && errno != EINTR)
		perror("select");
	    continue;
           if (FD_ISSET(l[i], &readfds)) {
               fd = accept(l[i], NULL, NULL);
               break;
	if (fd < 0) {
	    if (errno != EINTR)
		perror("accept");
	    continue;
	printf("accepted new connection\n");
	/* set ip addresses */
	salen = sizeof(local_ip);
	if (getsockname(fd, (struct sockaddr *)&local_ip, &salen) < 0) {
	    perror("getsockname");
	getnameinfo((struct sockaddr *)&local_ip, salen,
		    hbuf, sizeof(hbuf), pbuf, sizeof(pbuf),
#ifdef _SUN_SDK_	/* SOLARIS doesn't support NI_WITHSCOPEID */
		    NI_NUMERICHOST | NI_NUMERICSERV);
#else
		    NI_NUMERICHOST | NI_WITHSCOPEID | NI_NUMERICSERV);
#endif
	snprintf(localaddr, sizeof(localaddr), "%s;%s", hbuf, pbuf);
	salen = sizeof(remote_ip);
	if (getpeername(fd, (struct sockaddr *)&remote_ip, &salen) < 0) {
	    perror("getpeername");
	getnameinfo((struct sockaddr *)&remote_ip, salen,
#else
#endif
	snprintf(remoteaddr, sizeof(remoteaddr), "%s;%s", hbuf, pbuf);
	r = gethostname(myhostname, sizeof(myhostname)-1);
	if(r == -1) saslfail(r, "getting hostname");
	r = sasl_server_new(service, myhostname, NULL, localaddr, remoteaddr,
			    NULL, 0, &conn);
	if (r != SASL_OK) saslfail(r, "allocating connection state");
	/* set external properties here
	   sasl_setprop(conn, SASL_SSF_EXTERNAL, &extprops); */
	/* set required security properties here
	   sasl_setprop(conn, SASL_SEC_PROPS, &secprops); */
	in = fdopen(fd, "r");
	out = fdopen(fd, "w");
	r = mysasl_negotiate(in, out, conn);
	if (r == SASL_OK) {
	    /* send/receive data */
	printf("closing connection\n");
	fclose(in);
	fclose(out);
	close(fd);
	sasl_dispose(&conn);
    sasl_done();
