Solaris Trusted Extensions Installation and Configuration for Solaris 10 11/06 and Solaris 10 8/07 Releases
Zone Creation in Trusted Extensions
To create a labeled zone involves copying the entire Solaris OS, and then starting the services for the Solaris OS in every zone. The process can be time-consuming. A faster process is to create one zone, then to copy that zone or clone the contents of that zone. The following table describes your options for zone creation in Trusted Extensions.
Zone Creation Method
Effort Required
Characteristics of This Method
Create each labeled zone from scratch.
Configure, initialize, install, customize, and boot each labeled zone.
  • This method is supported, and is useful for creating one or two additional zones. The zones can be upgraded.
  • This method is time-consuming.
Create additional labeled zones from a copy of the first labeled zone.
Configure, initialize, install, and customize one zone. Use this zone as a template for additional labeled zones.
  • This method is supported, and is faster than creating zones from scratch. The zones can be upgraded. Use the Copy Zone method if you want Sun Support to help you with any zone difficulties.
  • This method uses UFS. UFS does not offer the additional isolation for zones that Solaris ZFS offers.
Create additional labeled zones from a ZFS snapshot of the first labeled zone.
Set up a ZFS pool from a partition that you set aside during Solaris installation.
Configure, initialize, install, and customize one zone. Use this zone as a ZFS snapshot for additional labeled zones.
  • This method uses Solaris ZFS, and is the fastest method. This method makes every zone a file system, and thus provides more isolation than UFS. ZFS uses much less disk space.
  • If you are testing Trusted Extensions and can reinstall the zones rather than upgrade, this method might be a good choice. This method can be useful on systems whose contents are not volatile, because the system can quickly be reinstalled to a usable state.
  • This method is not supported. Zones that are created by using this method cannot be upgraded when a later version of the OS is released.
Solaris zones affect package installation and patching. For more information, see the following references:
