Packages can be added by using the Java wizard or the pkgadd command. For options to the pkgadd command, see the pkgadd(1M) man page.
Insert the Solaris installation media into the drive.
Navigate to the Trusted_Extensions directory.
# cd Solaris_release-number/ExtraValue/CoBundled/Trusted_Extensions |
Load all packages.
Choose one of the following options:
Check for the proper installation of the packages.
In the Java wizard, click the Details button.
From the command line, scroll back through the log.
You can also go to the /var/sadm/install/logs directory and read the log.
You can also use the pkginfo command to confirm that the packages are installed.
# pkginfo | grep Trust system SUNWdttshelp Trusted Extensions, CDE Desktop Help system SUNWdttsr Trusted Extensions, CDE Desktop, (Root) system SUNWdttsu Trusted Extensions, CDE Desktop, (Usr) system SUNWmgts Trusted Extensions, SMC system SUNWtsg Trusted Extensions global system SUNWtsman Trusted Extensions Man Pages application SUNWtsmc Trusted Extensions SMC Server system SUNWtsr Trusted Extensions, (Root) system SUNWtsu Trusted Extensions, (Usr) system SUNWxwts Trusted Extensions, X Window System |
Java wizard – If the message Exception in thread "main" java.lang.NoClassDefFoundError: wizard appears, then you invoked the wizard from the wrong directory.
If you are upgrading a Solaris Trusted Extensions system, read the following before continuing:
Solaris 10 11/06 Release Notes
